Thread: Some more top swap questions! Yay!
Page 38 of 71 FirstFirst ... 28363738394048 ... LastLast
Results 741 to 760 of 1411
  1. #741 Re: Some more top swap questions! Yay!
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Most auto parts stores don't even have impacts let alone rent them
    Sent from my SM-G920V using Tapatalk
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  2. #742 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    If you know anyone with a shop or something I used a cordless snap on impact
  3. #743 Re: Some more top swap questions! Yay!
    GXP Level Member suitercrew's Avatar
    Oct 2015
    Ok ill check the rental in the morning or just see if my dad can bring his over tomorow. Now the map sensor wires are they excactly the same for the l67 map sensor
    Sent from my LG-D851 using Tapatalk
  4. #744 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    I'm not sure on that I'm using my L36 map sensor
  5. #745 Re: Some more top swap questions! Yay!
    if they are the same colors match em up. if not the same colors one wire might have a line on it, match the two with lines together.
    just twist and tape the wires till you know its working right, aka not setting a code. if all goes well solder them in.
  6. #746 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Lol yea and a couple map sensors later.....
  7. #747 Re: Some more top swap questions! Yay!
    Oct 2015
    Doesnt a black line usually mean its a ground?
  8. #748 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    It all depends how about some pictures of both sets of wires?
  9. #749 Re: Some more top swap questions! Yay!
    Oct 2015
    Old plug
  10. #750 Re: Some more top swap questions! Yay!
    Oct 2015
    New plug
  11. #751 Re: Some more top swap questions! Yay!
    see the a b c on the plugs, id try to match that up.
  12. #752 Re: Some more top swap questions! Yay!
    Oct 2015
    Ok well see haha
  13. #753 Re: Some more top swap questions! Yay!
    Oct 2015
    What goes in between the coil pack bracket and the tensioner is there a bolt or what. I cant get the tensioner to sit right
  14. #754 Re: Some more top swap questions! Yay!
    the long stud goes through the large hole on the coil bracket, then line up the bolt holes.
    zoom in on this pic,
    on the inside of the bracket is a 1/2 circle, the icm harness goes in there, watch you dont pinch the harness when bolting it down.
  15. #755 Re: Some more top swap questions! Yay!
    Oct 2015
    Ya but does anything go on the stud right after the coil bracket and before the tensioner. I put bracket on then very next thing was the tensioner and it just kind of sits funny
  16. #756 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Nothing goes on in between the braket and tensioner there's a little nipple on the back side of the tension that sides face you on top of the braket so it doesn't spin you probably just have to rotate it a litlle
  17. #757 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
  18. #758 Re: Some more top swap questions! Yay!
    Oct 2015
    So this is good?
  19. #759 Re: Some more top swap questions! Yay!
    Oct 2015
  20. #760 Re: Some more top swap questions! Yay!
    Jul 2015
    Jamestown, NY
    Looks good!
  1. top swap questions
    By 1976beef in forum Introductions/Noob Questions
    Last Post: 10-31-2015, 05:58 PM
  2. e85 swap questions
    By 04lss in forum Introductions/Noob Questions
    Last Post: 09-30-2014, 03:13 PM
  3. Swap questions
    By Bluemagic in forum General Grand Prix Discussion
    Last Post: 05-17-2013, 08:38 AM
  4. top swap questions...
    By ABINOK in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-13-2008, 12:33 AM
  5. A few top swap Questions
    By 02BlueGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-07-2008, 08:49 PM
