Re: Some more top swap questions! Yay!
hey before you go bolting the heads back on.
put your o2 sensor in the rear header, then lay your header in the back, then put the head on the engine, then pull the header to the head studs and nut it on there. then mark the fire wall where the o2 is close to hitting. unbolt the header remove the head and header, then dent the fire wall in. you will never have this much room to work in to clearance the o2.
suitercrew
Well im gonna reuse my l36 pushrods and rockers since i wasnt able to get the 1.9s so there still pretty oily haha
Sent from my LG-D851 using Tapatalk
scrub them up clean, dont put dirty parts back on.
Well i was going to put the front head on and set up the front header portion and then work on the back cause i have both dogbones out right now to get more clearance in the front. Theres 0 clearance in the back right now
Ok ill get scrubbn!
front header is the last part that goes on. you read the header install thread yet?
is the rear head on still? once you get the two brackets off the head you can see wtf your doing real easy.
The rear head is still on
get the alt and the brackets off and you can see every thing. leave the two brackets off too, and the one on the front head. cleans up the engine, you dont need em.
Ok scotty! So no adjustment is needed on the rocker arms right?
Adjustment on the rocker arms???? What are you talking about they don't adjust lol that's what hydraulic lifters are for...
Sent from my SM-G920V using Tapatalk
Lol thats what i thought my dad just kept asking me if i knew how to adjust them. (hes a little old school)
its not a solid lifter cam. line em up tq em down.
if you spin the engine so both valves are closed then tq em, you know they are all done evenly. use the crank bolt to spin the engine.
Ok
So after 30 minutes i finally got the whole 4 bolts off that hold the black brackets on and you were right scotty without those stupid brackets its a lot easier.
Can someone tell me if these are tty or reusable? I ordered the reusable but on their website it says the torque specs are 25ft lbs but on the bag it give different torque specs with the extra degreees which makes me believe they messed up and sent me tty
what bolts are they? brand? if they are tty i think the bolt head is marked.
the allen head rocker bolts are re usable for sure.
sounds like a tty spec to me. odd for sure.
So hmm.. Call intense i guess? Lol i finally got the rear head off and manifold and dp. Almost ready to start putting it back together!!
I bought these same bolts from intense, checked out as reusable but came packaged the same way.
Ok thanks! So do they get torqued to 25ft lbs?
