Ya when my dad stops ignoring me ill see if he still has the reciept and can get the item number. We just figured they went with a different design
Sent from my LG-D851 using Tapatalk
when you change the whole canister they add a new pig tail for one of the plugs. you cut off the stock one, install the new pig tail provided.
Yes thats what i did! But why do they make the plugs different?
Where do I get methonal?
Sent from my SM-G920V using Tapatalk
For real? -20 so any washer fluid that goes down to -20? How much of it do you actually use?
you fill the res tank, the spray nozzles dictate how much is sprayed. some how its only sprayed when your wot or starting to hit boost, theres a controller for it.
ive not looked into much (like how the set up works) cheaper then a IC thats for damn sure. way less work to install too.
Okay I was just curious about how much meth you use for a gallon of gas ya know?
its not a full time deal, only when in boost, then it sprays.
How do you tune for that?
But what happens for when the pump for the meth goes out and then you explode your motor lol?
I mean i guess if maybe you had an aeroforce and kr was constantly in your face youd probably have warning to stop driving
why you scan for kr full time.
Scotty would you recommend a meth set up for my setup ?
im not sure if having a tuner helps with meth or not, or if it needs to be tuned for it. with a tuner you can play with your timing at least. no tuner and your stuck with what you got.
Should i replace the hb seal?
as per billboost, dont change it unless you see its damaged. install the l67 balancer, if it leaks you need to change it. bill said hes only had a few that leaked. the times the owner wanted a new seal, it leaked on him lol
i changed my seal and nothing good came of it. 4 days of trial and error i guess lol
Ok thanks
