Sounds like it I think there's older models of the aeroforce though I talked to a guy that has the same car as mine and he had to get a special adaptor to update it so it could read oil pressure not really sure though.
Who's selling these?
Well its a guy locally to me but there from a mustang which is why idk if there different between cars
Sent from my LG-D851 using Tapatalk
Oh yea they are it won't work they are different between 97-03 vs 04+ grand prixs.
O aww that stinks.. I guess 200 more dollars i have for any misc top swap parts i need. I still really need to find some 1.9s
The wideband and boost gauge will work though I'm actually lookin for a wideband will he separate them?
I asked him and he said no but maybe in a few days hed be more interested
Okay let me know
So just wanted to double check my head gaskets came in today both sides are the same correct? On rock auto there was a victor reinz head gasket and they had a part number for the left and another for the right but the felpro ones were the same for both sides
yup felpro is two of the same gasket, one goes on right, the other backwards. aka the arrow on the gasket.
see the arrow under the 2 nd bolt from the right side of the head.
http://i1097.photobucket.com/albums/...pso8j1kr0j.jpg
Ok just wanted to play it safe thanks scotty! On a side note i finally went and got all the sc pulleys tensioner and idler tower from a scrap yard today, came home and dont have the bolt that holds the tensioner on... Scrap yard is a 40 min drive away..
how you forget that one important bolt?
if you can figure out top from bottom, hang it up now rosco......
Idk i just took the tensioner off and didnt even think about it. I was in a rush because my fiance wanted to spend time with me so she tagged along and of course after 5 minutes.. "Are you almost done yet?"
No one happens to have a spare one of those do they? Also i know the lim bolts are the same but is the supercharger bolts the same as l36 manifold?
lim bolts are the same. you kinda need/want that nut, and the stud it was on.
you got the idler stand bolts too right? you need those also.
I do have the stand and its 3 bolts the gp was a 97 hopefully its all the same. Arent the studs on the l36 the same or is it an extra stud? I know the lim bolts are the same but i didnt know if the uim bolts are the same. Im missing a couple of those as well
