Thread: Downshifting an automatic trans
Results 1 to 20 of 93
  1. #1 Re: Downshifting an automatic trans
    Dec 2008
    indiana
    Quote Originally Posted by Sabrewings View Post
    I hope you know you're hurting your transmission. Those lower gears are for engine braking, not hot-dogging it. Use them going down a hill when you don't want to get brake fade by heat soaking (riding) your brakes. Don't use them like your car is a manual.
    actually the lower gears were made for climbing up a steep hill or towing(although i dont know who would put a hitch on a GTP). and how would i be hurting my transmission if i shift the car rather than the car shift itself? im not trying to be an a**, im just asking a question
  2. #2 Re: Downshifting an automatic trans
    Barksdale AFB, LA
    Quote Originally Posted by projectGTP View Post
    3 is for towing. 1 and 2 are for engine braking. When you pull it down into those gears, it uses different internal mechanisms called manual bands instead of the clutch packs. They are designed to provide engine braking with higher line pressure than you could use the standard clutch packs for.
    When you leave it in D or 3, the tranny uses its first or second gear clutch packs to use those gears instead of the manual bands.
    Trannyman probably has a more eloquent way of putting it, and he can surely show you pictures of toasted manual bands from people doing like you're doing.
    2009 Subaru Impreza WRX STI
  3. #3 Re: Downshifting an automatic trans
    Dec 2008
    indiana
    sounds pretty complicated. lol. would this apply to every car or only GTPs? cuz i did this with my old grand am and never had a problem.
  4. #4 Re: Downshifting an automatic trans
    Barksdale AFB, LA
    Depends on the transmission. This for sure applies to any car with the 4T65E. Grand Prixs, Impalas, Monte Carlos, Regals, etc. I think the Grand Am has the 4T40E, which I haven't paid much attention to.
  5. #5 Re: Downshifting an automatic trans
    Dec 2008
    indiana
    oh. and it was a 93 grand am with a 4cyl. lol. wasnt the quickest car
  1. converting from automatic to manual
    By 3800John in forum 1991-1994 5 speed Manual (GETRAG 284,282)
    Last Post: 03-29-2010, 07:36 PM
  2. Automatic Downshifting
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-23-2008, 08:12 PM
  3. Trans has a hard time downshifting when its cold?
    By Tengis in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2008, 10:38 AM
  4. Automatic CLimate control lights.
    By RichCresci in forum Visual/Body Modifications
    Last Post: 08-15-2008, 09:35 AM
