actually the lower gears were made for climbing up a steep hill or towing(although i dont know who would put a hitch on a GTP). and how would i be hurting my transmission if i shift the car rather than the car shift itself? im not trying to be an a**, im just asking a question
3 is for towing. 1 and 2 are for engine braking. When you pull it down into those gears, it uses different internal mechanisms called manual bands instead of the clutch packs. They are designed to provide engine braking with higher line pressure than you could use the standard clutch packs for.
When you leave it in D or 3, the tranny uses its first or second gear clutch packs to use those gears instead of the manual bands.
Trannyman probably has a more eloquent way of putting it, and he can surely show you pictures of toasted manual bands from people doing like you're doing.
