Thread: Another problem, yay
Results 1 to 3 of 3
Threaded View
  1. #1 Another problem, yay
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I noticed last night, when I make a left turn that at about 15-20 mph I hear a grinding noise, almost like the noise when you have low traction ect.
    I recently did the following work:
    Both front lower control arms, front left wheel hub, both sway bar links, bushings, left outer tie rod, both front ball joints.
    I have not gotten a alignment and my steering wheel sits at about 2 oclock if your comparing it to a clock.
    Should a alignment fix the "grinding" type of noise. What else could be the issue besides what I already just had fixed a week ago.
    On Thursday im having a GM dealership do the alignment so its right on with the specs of the car, its a 2000 gp gt 2 door 170K miles, which most of the work is normal wear and tear for the car that hasn't been taken care of. They might be able to look the problem over.
  1. Need a direction to my GP's problem - FWD problem
    By isaac33 in forum General Grand Prix Discussion
    Last Post: 02-26-2013, 11:36 AM
  2. Is it a problem on my end? Picture Uploading Problem.
    By TJeno in forum Forum Bugs/Suggestions
    Last Post: 10-23-2012, 07:53 AM
  3. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  4. MAF problem- maybe?
    By Betsy in forum General Tech Discussion
    Last Post: 12-19-2010, 08:36 AM
  5. Problem
    By mwillis in forum Introductions/Noob Questions
    Last Post: 10-05-2010, 03:54 PM
