Thread: Shift Kit Question!
Results 1 to 8 of 8
  1. #1 Shift Kit Question!
    Apr 2013
    White Lake
    2005 GP GT 127k
    Soooooooo I recently installed a shift kit in my car and it made a HUGE change in my shifting! Its been about 3 weeks now and I have had 0 problems with my trans. Before I thought it was slipping but I believe it the PCM was doing something to make control pressure solenoid to go into maximum pressure where it would take awhile to shift "around 3k rpms before I shifted and it would shift hard" Shift kit fixed that so far....
    My question about the shift kit is that when I put it in 3rd "quite", 2nd "quite", 1st... it makes some kind of buzzing noise and it never did that until I put the kit in "I THINK" Is that normal or not? Also when I was putting new fluid in after the install when fluid was going down hole I could hear like air coming out of somewhere??? Trans fluid level is perfect still and 0 leaks!
    any help would greatly appreciate it!!!
  2. #2 Re: Shift Kit Question!
    wtf does this mean? "when I put it in 3rd "quite", 2nd "quite", 1st..." like your down shifting the trans? if so stop doing that.
  3. #3 Re: Shift Kit Question!
    Never Be A Tim. ILoveAudi's Avatar
    Aug 2012
    Middle of Nowhere, OH
    Quiet... not quite :facepalm:
    1998 GTP Coupe - DIY Intake, Stock - 178k miles with rusty weight reduction (sold)
    1998 GTP Sedan - CT turbo kit, billet wheel pt61, s1x blower cam, Iceman stage 3 heads, 90# springs for all the valve floatz, walbro pump, fuel pump rewire *slowest s1x build ever*
  4. #4 Re: Shift Kit Question!
    Feb 2013
    Missouri
    When you put the transmission in manual first, it's at full pressure so it's normal to hear it whine a little. Where is the fluid at on your dipstick? A lot of times you want it at the top or a little above the cross hatch.
  5. #5 Re: Shift Kit Question!
    dont down shift, your engine and tranny are trying to roll over in the bay. theres nothing to gain but broken parts.
  6. #6 Re: Shift Kit Question!
    He is talking while not moving.
    What you hear is normal, just about every single auto tranny when put in Manual 1 will make extra noise from the pump and internals. As that guy said, it just like full pressure and is wanting everything there because the shifter is set there.
  7. #7 Re: Shift Kit Question!
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    THIS
    I always manually run through the gears sitting still after a fresh trans fluid/filter change.
    Not sure I would have explained it "quite" like that though...lol
    OP: What do think is in that trans pan you are refilling with fluid...air that is being displaced by that fluid which has to go somewhere.
  8. #8 Re: Shift Kit Question!
    Apr 2013
    White Lake
    Lmao my bad... long weekend and I posted this right before I went to bed. Yes standing still and going through the gears!
  1. Shift kit question??
    By Cali boi in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-25-2014, 09:11 PM
  2. diy shift kit question..
    By IntenseFace in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-29-2012, 12:18 PM
  3. 99 GTP shift question
    By GTP78 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-08-2012, 06:12 AM
  4. Another shift kit question
    By Compg4me in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-22-2012, 09:32 PM
  5. shift kit question?
    By hardrocrick in forum General Tech Discussion
    Last Post: 08-26-2011, 06:24 AM
