Thread: Too many Damn problems
Results 1 to 20 of 26
  1. #1 Too many Damn problems
    Aug 2014
    My 03 grand prix gt was recently in the shop for all new intake manifold, intake manifold gasket, thermostat, and a heater hose connector. When my friend picked it up to take to my house it died, in a 3 block span. The next day it died 4+ times going across town. Personally I dont know **** about cars and could really use the feedback, thanks guys.
  2. #2 Re: Too many Damn problems
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    Quote Originally Posted by neverstockgt View Post
    Not quite sure your problem, could be something simple like clogged fliter..
    Are you sure the mechanic did the work right? I have had the lower intakes, upper intakes, valve covers done on a 2001, and a 2000 gt and they drive fine after, never had one die on me. Does it start right back up after it dies?
  3. #3 Re: Too many Damn problems
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    If stock, check for a vacuum leak, possibly suspect poor installation of the upper intake manifold. Also there's a number of vacuum lines around the motor that could have dry rotted out by now.
    Could also be a crank sensor or an ignition issue. Do you have any more details about when it dies?
    Also could be fueling. Does it only die when you get on the gas? If so, it's a clogged fuel filter.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  4. #4 Re: Too many Damn problems
    Aug 2014
    Before this shop I had a new cat converter put then a little after it went to this shop and now after it will kinda bog down before it dies, it start right back up no problem but when I take off it tries to die. Also have recently put a new fuel filter in.
  5. #5 Re: Too many Damn problems
    Jun 2013
    Beavercreek, OH
    If the car bogs or dies when under throttle it could either be a bad cat (bad on installation?) or still lack of fueling comes to mind. Fuel pump could be on its way out but I still think the cat is responsible here.
    If you live in an area with no inspections just get a catless downpipe or some speed daddy headers off ebay for $200.
  6. #6 Re: Too many Damn problems
    Aug 2014
    Well I took it to a muffler shop and it ran perfect for like 2 weeks after the cat was put in. And I was told there is an o2/oxygen sensor so it has to have one
  7. #7 Re: Too many Damn problems
    Jun 2013
    Beavercreek, OH
    The shop lies. 97-03 W-bodies don't need a rear 02 sensor (the one behind the cat). It'll throw a service engine soon light if you don't have one (p0141 if I recall correctly) but won't affect the way the car drives at all.
    The front 02 sensor matters, but the rear one only measures catalyst efficiency.
  8. #8 Re: Too many Damn problems
    Aug 2014
    Hmm well im taking it back to the shop in the morning and im really hoping its just something simple
  9. #9 Re: Too many Damn problems
    SE Level Member Southerngoodness's Avatar
    Jun 2014
    Evans GA
    It could be something as simple as a mass airflow sensor. Mine was bad and all my car did was die at the end of my driveway
  10. #10 Re: Too many Damn problems
    Cambridge, Ontario Canada
    Maf or crank sensor if it starts then dies. Any codes?
    2005 E55 - stock
  11. #11 Re: Too many Damn problems
    Jun 2014
    Evans GA
    Mine never threw any codes just died but I fixed that problem with a maf from the local pullapart
  12. #12 Re: Too many Damn problems
    Aug 2011
    'Merica
    IIRC if your downstream o2 sensor is throwing a code, it will make the car dump a bunch of gas trying to compensate for the o2 not being there.....crappy MPG's. I would unplug the MAF then start the car to see if it stays running, if it does your MAF is probably dead. I would make the "shop" look at everything. If they find the issue, they pay since it ran fine before they screwed with it.
  13. #13 Re: Too many Damn problems
    Jun 2014
    Evans GA
    Ok wats the avg mpg for the 98 gtp cause I'm at around 16
  14. #14 Re: Too many Damn problems
    Aug 2011
    'Merica
    Is that city or highway or just a guess at both? I think people are seeing mid 20's being SC. I'm NA so mine will be different. I have an aftermarket cat and it is throwing a code and the gas mileage sucks right now.
  15. #15 Re: Too many Damn problems
    Aug 2013
    McDonald PA
    Quote Originally Posted by Below Average Joe View Post
    eBay fouler lol mine sucked too and then I did that and see 22 city
  16. #16 Re: Too many Damn problems
    Aug 2011
    'Merica
    can't get the o2 out....have tried 3 times. I have a fouler ready to go in..............Dan is just going to tune it out anyway
  17. #17 Re: Too many Damn problems
    Aug 2013
    McDonald PA
    I need a smutty tune too since hpt can tune 06/07
  18. #18 Re: Too many Damn problems
    Aug 2011
    'Merica
    Sure he can.....he's getting better. He has DHP and HPT
  19. #19 Re: Too many Damn problems
    Aug 2014
    So I guess its the mass airflow sensor is what the shop told me.
  20. #20 Re: Too many Damn problems
    Quote Originally Posted by hensleya1 View Post
    This statement is only partly true. 97-00 don't need a rear o2 sensor, 01+ need an o2 sensor or the cat diagnostic test gets stuck on and the car will dump fuel. http://www.grandprixforums.net/threa...ou-should-know
  1. Damn 5-0!
    By K Kraziee in forum Visual/Body Modifications
    Last Post: 11-21-2013, 11:35 AM
  2. Damn...
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 02-16-2012, 11:24 PM
  3. Damn it MOM!
    By JoshsGTP in forum Off Topic Discussion
    Last Post: 06-02-2011, 08:07 PM
  4. :( damn...
    By nicksilvergt99 in forum Track Sessions and Kills
    Last Post: 08-28-2009, 12:26 PM
  5. Damn damn damn!
    By GTPRiley in forum The Rant Forum
    Last Post: 04-21-2009, 11:15 PM
