Thread: 00 ignition cylinder issue
Results 1 to 8 of 8
  1. #1 00 ignition cylinder issue
    Jul 2014
    Just bought this 00 gp gt and it didn't come with any keys. Replaced the cylinder and it seems like the switch doesn't turn all the way off and the key won't come out. Also the security continuously flashes. I read on the buying guide for these cars and it said the brake light sensor can cause the cylinder to not release the key but would it cause the security light to keep flashing when the car is running? I did shave the magnetic plate down or whatever it is on the cylinder so I was able to get the key out.
  2. #2 Re: 00 ignition cylinder issue
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    Pull the steering wheel up there's a little release button under the steering column. I have to press it about half the time
    As to the security light flasking, that's probably the PK3 thing. I don't know much about that, I hate electronics
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  3. #3 Re: 00 ignition cylinder issue
    Jul 2014
    I had no idea there was a release I even looked I must have missed it
  4. #4 Re: 00 ignition cylinder issue
    Jul 2014
    Campbell CA
    johnnie06, ignition key - Pass-key 3 system will need a chipped key. If you do have the correct (security / chipped) key. Perform 30 minute relearn procedure.
  5. #5 Re: 00 ignition cylinder issue
    Jul 2014
    Would it work with the keys that came with the new cylinder
  6. #6 Re: 00 ignition cylinder issue
    Jul 2014
    Campbell CA
    What does the key look like? Bare metal key? Oem chipped keys have a gray plastic around the head.
  7. #7 Re: 00 ignition cylinder issue
    Jul 2014
    Dark grey to black head says gm
  8. #8 Re: 00 ignition cylinder issue
    Jul 2014
    Campbell CA
    That could be the key -
    Try this -
    The battery has to be in very good condition and fully charged. 30 min relearn - Turn ignition on, security light must be on. Wait 10 minutes, security light will go out. Turn ignition off for 5 seconds. Repeat two more times. Total of 30 minutes. For the last step, leave ignition off for 30 seconds before trying to start the engine.
    Make sure headlights stay off, HVAC system off, radio off. Your battery must maintain system voltage over 11 volts during this process. Most battery chargers produce to much ac voltage to use during relearn. Computers hate ac (alternating voltage) voltage.
  1. Key stuck in ignition lock cylinder
    By rfmgtp02 in forum General Tech Discussion
    Last Post: 01-17-2019, 10:47 AM
  2. ignition lock cylinder inquiry
    By kidscar2004 in forum General Tech Discussion
    Last Post: 07-09-2012, 06:41 AM
  3. ignition lock cylinder removal for a 98 regal
    By Scottydoggs in forum General Tech Discussion
    Last Post: 06-25-2012, 11:20 AM
  4. replaced bcm and ignition cylinder and NEED HELP
    By bkatrenak in forum Audio, Security & Visual Electronics
    Last Post: 03-11-2011, 05:08 PM
  5. ignition switch cylinder
    By mtz956 in forum General Tech Discussion
    Last Post: 08-29-2010, 02:21 AM
