Thread: Check Engine Light with ZZP downpipe (catted)
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 64
  1. #1 Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    Is it a common issue when buying the catted down pipe to get a check engine light saying the cat isnt doing its job because its high flow?
  2. #2 Re: Check Engine Light with ZZP downpipe (catted)
    GTP Level Member indygrandprix's Avatar
    Jan 2012
    Indianapolis
    Yeah its common just do the spark plug non fouler trick. If that doesn't work then you prbly need a new O2 sensor. Did it work before?
    I went NA when a whore left -$300 in my bank account.
  3. #3 Re: Check Engine Light with ZZP downpipe (catted)
    antioch ill
    yup i had it then i reset the code its fine now. i emailld zzp about it. they told me i needed to buy a canned pcm from them so it will turn off the code
  4. #4 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    I haven't bought it yet. I was asked if I wanted it for Xmas. But if it throws the code my parents said its on me cause it won't pass inspection so I was debating on it. And what's the non fouler trick
  5. #5 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    Quote Originally Posted by Matt Palm View Post
    So all you did was get it cleared from like auto zone. No need for a tune to clear it?
  6. #6 Re: Check Engine Light with ZZP downpipe (catted)
    SWPA
    When I bought mine ZZP offered a "built in" non fouler. My cat code has tripped twice since then. Its been over a year since I last reset it.
  7. #7 Re: Check Engine Light with ZZP downpipe (catted)
    what year is is your car? the 01 dont like the o2 to be deleted.
    you could find a local to tune it off if its not a 01. if its a 01 your want to try the flouler trick for sure.
  8. #8 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    It's an 06
  9. #9 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    I'll just get it put anti sieze on the bolts and swap it for inspection
  10. #10 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    I'll have to look into that. Is it a special order
  11. #11 Re: Check Engine Light with ZZP downpipe (catted)
    SWPA
    It was one of the options when I got mine. It was a "No SES" option or something like that. Last time I looked I think they stopped offering it. Any non fouler available at a parts store will keep the cat code away.
  12. #12 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    I don't understand the non fouler concept or how it works or how to install it
  13. #13 Re: Check Engine Light with ZZP downpipe (catted)
    Jan 2012
    Indianapolis
    http://www.355nation.net/forum/how-p...ight-pics.html
    This should give you an idea of what it is
  14. #14 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    I feel like I could handle that
  15. #15 Re: Check Engine Light with ZZP downpipe (catted)
    antioch ill
    my aeroforce resets the code
  16. #16 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    Ohh well I guess well see what happens
  17. #17 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    Ordered the down pipe. For gaskets do the stock size work? Or do I need to order them from zzp also. I was hoping I could get them at advanced
  18. #18 Re: Check Engine Light with ZZP downpipe (catted)
    antioch ill
    stock sizes work. and dont be suprised if you snap the bolt off in the cat back flange. I know i did and many others. I only had 35k miles on mine when i snapped it
  19. #19 Re: Check Engine Light with ZZP downpipe (catted)
    Keep stick unless they're beyond repair. There metal so just brake clean then and reuse.
    04 Comp G.
  20. #20 Re: Check Engine Light with ZZP downpipe (catted)
    Aug 2013
    McDonald PA
    I'm hoping a lot of penetrating oil some heat will be ok
  1. Lock it up
    By PurpleGuy in forum Wanted To Buy - Parts
    Last Post: 10-14-2013, 03:06 PM
  2. Lock it up
    By PurpleGuy in forum For Sale - Parts
    Last Post: 09-26-2013, 03:42 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. check engine light and lose wire in engine bay
    By Fcukit33 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-13-2011, 05:29 AM
  5. Check Engine Light
    By lemmy33 in forum General Tech Discussion
    Last Post: 11-03-2011, 04:10 PM
