Thread: Broken Tachometer, help.
Results 1 to 5 of 5
  1. #1 Broken Tachometer, help.
    SE Level Member Metal Links's Avatar
    Dec 2013
    NJ
    I just recently purchased a 2004 Pontiac Grand Prix gt, 66K miles. A few days ago I noticed my tacho was at 1k when the car was off, and would randomly slowly go back down to zero. It seems to respond when I hit the gas but then it starts falling when I maintain speed.
    How would I fix this and how concerned should I be?
  2. #2 Re: Broken Tachometer, help.
    So it sometimes falls to zero while driving?
    Has it ever stalled on you yet??
  3. #3 Re: Broken Tachometer, help.
    Dec 2013
    NJ
    It seems to get stuck at 1000 rpm when falling. The best description for its movement is floaty or bouncy... It stalled once when I first started it, I heard it start and then it just stopped. Almost like it was not getting enough fuel. The stalling only seems to happen when the car is warm. There is also a strong smell of gas/exhaust when I idle in the morning to de-ice the car.
  4. #4 Re: Broken Tachometer, help.
    St. Louis
    Time to remove and clean the throttle body. They get carboned up on the back of the butterfly and cause issues.
    From there, it may be time to suspect a crankshaft position sensor.
  5. #5 Re: Broken Tachometer, help.
    Dec 2013
    NJ
    I cleaned the throttle body. the back was coated in carbon and the front had white-ish specks on it....almost looked like salt deposits. I havn't notice the issues yet, I will keep you guys updated.
  1. Tachometer goes to 0 while driving
    By corsagtp in forum General Tech Discussion
    Last Post: 02-04-2013, 01:44 PM
  2. Old Thread
    By SpeedGrid in forum General Tech Discussion
    Last Post: 09-03-2012, 09:23 PM
  3. PLEASE HELP!!!! Tachometer keeps jumping!!!!!!
    By Donald Mosley in forum General Grand Prix Discussion
    Last Post: 12-18-2011, 11:29 PM
  4. Tachometer Dies Out, Help?
    By Frank217 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2011, 06:39 PM
  5. tachometer
    By Chleby in forum General Tech Discussion
    Last Post: 09-09-2008, 09:51 PM
