Thread: running ruff, need help
Results 1 to 10 of 10
  1. #1 running ruff, need help
    SE Level Member manny's Avatar
    Aug 2013
    FLORIDA
    I have a 97 GP GT 3.8 vin K. After sitting it sucks air heavy thru the throttle body and runs rough for a few minutes not when you start it but a few minutes after doesn't matter hot or cold. It will then clear itself up and run fine. Has new mass air sen, idol air sen, and purg sen. no vac leaks or check engine light.
  2. #2 Re: running ruff, need help
    spray the throttle body area with some brake cleaner and see if the idle changes if you do you have a leak likely the gasket between the supercharger and throttle body.
    that's where id start at least. I doubt its a sensor if the car runs fine after it few minutes.
  3. #3 Re: running ruff, need help
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    Just got a 2000 SE 3.1 and this is a learning experience for me. But I just cleaned my MAF and one of the boots has a inner lip. I didn't get it on right it was folded in and it sucked air til I figured it out
  4. #4 Re: running ruff, need help
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    maybe bad fuel pressure regulator if it only does it after it sits try turning the key on like ur going to start it and remove the vac hose from the fuel pressure regulator and see if it is wet
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  5. #5 Re: running ruff, need help
    Banned
    Oct 2013
    Moorhead, MN
    I took my FPR hose off to adjust the bleeder on the water inlet.
    Fuel.
    Sad.
    Only I would grab a jy fuel rail that happened to have a bad regulator. LOL.
    Clean up your TB and all sensors leading up to the UIM.
  6. #6 Re: running ruff, need help
    Banned
    Oct 2013
    Moorhead, MN
    Don't Faulty o2 sensors sometimes act up until they get warm?
    Or possibly the FPR?
  7. #7 Re: running ruff, need help
    Start with a throttle body cleaning. The maf being new, what brand did you get. We often see refurbished sensors/even new non Delco/Delphi sensors causing issues. Also wiring in that area is suspect due to it being heated by the exhaust.
  8. #8 Re: running ruff, need help
    Aug 2013
    FLORIDA
    thank you all really appreciated going to do everything you guys suggested thanks again
  9. #9 Re: running ruff, need help
    Aug 2013
    FLORIDA
    thanks again everyone. found the new purge sensor was bad, thanks auto zone. still having the same problem. checked the intake and throttle body gaskets for leaks, fpr is dry. I'm thinking bad tb , sounds and runs like its choking. last place i can think to go.
  10. #10 Re: running ruff, need help
    Aug 2013
    FLORIDA
    Thanks for the info. checked for leaks, no leaks. The only thing I can think of is the throttle body. that's where it's choking. what do you think? thanks again.
  1. Ruff idle, low vac.
    By bigburban in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2013, 11:24 AM
  2. losing antifreeze and exhaust fumes in overflow and idling ruff
    By justcorrected in forum General Tech Discussion
    Last Post: 04-24-2012, 09:03 PM
  3. ruff r 933 black with falken ziex-ze912
    By vailskier3 in forum Tires & Wheels
    Last Post: 05-05-2010, 01:47 AM
  4. FINALLY RUFF R933's
    Last Post: 05-05-2010, 01:32 AM
  5. Ruff Idle
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 12:10 AM
