Thread: losing antifreeze and exhaust fumes in overflow and idling ruff
Results 1 to 20 of 37
  1. #1 losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2012
    Kentucky
    I just bought a 04 Grand Prix and it is losing antifreeze and there is a strong exhaust smell in the overflow tank. It seems like it is burning it thru the exhaust and idles ruff. Any ideas???
  2. #2 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2009
    Fort Worth TX
    Blown head gaskets are very rare on the 3800. Did it overheat?
    What car is it?
  3. #3 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2012
    Kentucky
    I dont think so i just bought it.
  4. #4 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    If you pull the radiator cap off, do you see exhaust bubblining in there? The overflow may be tough to check for the smell because a downpipe leak may be close enough to smell. Also I wouldn't trust the smell of most overflows. Seeing it in the radiator, that I would trust.
  5. #5 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2009
    Fort Worth TX
    So it is the 3800? This is so rare that we're going to wait until someone else chimes in 'cause I don't even know where to start.
    How many miles are on it?
  6. #6 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Yo Chuck...I chimed
  7. #7 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2009
    Fort Worth TX
    Yo Chuck...I chimed
    Good thing, thanks
  8. #8 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2012
    Kentucky
    Sorry i put this in the wrong place. I hope someone has an idea.
  9. #9 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    GT Level Member lrscgod's Avatar
    Shellman Bluff, GA
    I'd start with the LIM gaskets anyway. I just had to do the LIM on my sons 2003 Impala that he just got two weeks ago from his grandma. it only has 43000 miles on it.
    4 out of 3 people have trouble with fractions
  10. #10 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2009
    Fort Worth TX
    Bill, would a compression test help here even if it's a small leak?
  11. #11 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Put in general until we know which motor it has.
  12. #12 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2012
    Kentucky
    It is the 3800 Series II . Someone told me that is what it might be. Are they hard to do on the 3800?
  13. #13 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Shellman Bluff, GA
    No it's not that hard. I had my sons car done in less than three hours. And put a new coolant elbow in too, they get brittle.
  14. #14 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2012
    Kentucky
    I dont want to put alot into the motor if that is not the problem since the odo is showing 280000. I would rather put a motor in it.
  15. #15 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Shellman Bluff, GA
    Well you could sell me a 3800 with 200 miles on it and i'd still do the aluminum LIM right then.
  16. #16 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Really...I'd look to see if it had aluminum gaskets first.
    I'd start by taking off the rad cap and bringing it up to temp. Look for bubbles in the radiator. It's the single easiest HG test you can do, and pretty damn accurate too. LIM gaskets might consume some coolant, but it's not typically much at all. Now..since you say 3800 S2 and not saying supercharged, I can toss this at you to check. This is one of the most common issues with a non charged 3800 using coolant.
    http://www.grandprixforums.net/97-03...ure-60667.html
    It would be relatively cheap to pull the upper, drill and plug the LIM (even on the car. Then keep on motoring til the engine finally blows. Plugging into in this thread
    http://www.grandprixforums.net/how-mod-lim-46931.html
    Is plugging really a good thing on the motor, not really. You can get some metal shavings in the coolant. Likely it won't hurt a thing though. I would do it in the case you are describing.
  17. #17 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2009
    Fort Worth TX
    I see what your saying with the UIM but that would have to be one heck of a hole in the plastic manifold to get that much exhaust in the cooling system. Possible though.
    Mine had a pinhole or two but there wasn't even any bubbles in the rad. It was just using coolant...had to refill every two or three days.
    If it is the UIM I want to see a picture of it.
  18. #18 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Chuck..no amount of hole would get exhaust in rad. In case he's incorrectly diagnosing the exhaust in teh coolant and he's just loosing, then this applies. I suggest testing and looking to confirm first.
  19. #19 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Apr 2012
    Kentucky
    I did notice now that sometimes when it idles there is a steamy smoke like from the exhaust. But when u start it it dies the first time or 2 then it runs alittle better. I got it for $1600 dollars so i figured if i had to put a motor in it it wouldnt be too bad cause the body and interior is in exclent shape.
  20. #20 Re: losing antifreeze and exhaust fumes in overflow and idling ruff
    Wouldn't you like to do even less and drive it a crapload of miles for nearly nothing? =0) I would.
  1. exhaust fumes.
    By TheManInBlack in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-07-2012, 01:37 AM
  2. Losing Coolant from Overflow tank
    By Suaveat69 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-12-2010, 10:00 PM
  3. Ruff Idle
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 12:10 AM
  4. Heater Spewing Exhaust Fumes
    By Michael Lomb in forum General Tech Discussion
    Last Post: 10-20-2009, 09:39 AM
  5. Faint smell of antifreeze in exhaust
    By firstdue in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2009, 09:00 PM
