Thread: running ruff, need help
Results 1 to 10 of 10
  1. #1 Re: running ruff, need help
    spray the throttle body area with some brake cleaner and see if the idle changes if you do you have a leak likely the gasket between the supercharger and throttle body.
    that's where id start at least. I doubt its a sensor if the car runs fine after it few minutes.
  2. #2 Re: running ruff, need help
    SE Level Member manny's Avatar
    Aug 2013
    FLORIDA
    Thanks for the info. checked for leaks, no leaks. The only thing I can think of is the throttle body. that's where it's choking. what do you think? thanks again.
  1. Ruff idle, low vac.
    By bigburban in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-27-2013, 11:24 AM
  2. losing antifreeze and exhaust fumes in overflow and idling ruff
    By justcorrected in forum General Tech Discussion
    Last Post: 04-24-2012, 09:03 PM
  3. ruff r 933 black with falken ziex-ze912
    By vailskier3 in forum Tires & Wheels
    Last Post: 05-05-2010, 01:47 AM
  4. FINALLY RUFF R933's
    Last Post: 05-05-2010, 01:32 AM
  5. Ruff Idle
    By SlowM90 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-30-2009, 12:10 AM
