Thread: Window Question
Results 1 to 11 of 11
  1. #1 Window Question
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, while I was driving yesterday the front passenger window started to roll itself down, and neither switch did anything (up or down). I assume the window motor is a good place to start - is the window motor the same on a coupe and sedan? Then I can just grab the one off my parts car and see if that fixes it.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Window Question
    Jan 2014
    AR
    I would be thinking switch, not motor. If it suddenly grew a mind of it's own and is inoperative since then. Could be either front switch. Get out a test light or multimeter and track it down. Sedan and coupe window motors same?- could be, and a quick part number search should get you that answer. Just look up both cars somewhere, see if numbers are same.
  3. #3 Re: Window Question
    Jun 2015
    Oh, okay. I'll do that.
    Oh, duh...., somedays I wonder about myself.
    Thanks!
  4. #4 Re: Window Question
    Jan 2014
    AR
    Sometimes I gotta just buy a vowel or something too, no worries!
  5. #5 Re: Window Question
    Mar 2014
    Tucson
    Did it roll down or fall down? A broken actuator will let the window creep down on its own.
  6. #6 Re: Window Question
    Jun 2015
    I looked over and it was half down, attempted to use driver's and passenger's button to go up or down and it did nothing. Looked over 5/8 minutes later and the top of the window was an inch from being gone, tried again, nothing. I assume it was just slowly going down. Today, I tried to see if it was loose up/down or anything and it fell down the remaining inch quickly without resistance when I fooled with it.
  7. #7 Re: Window Question
    Mar 2014
    Tucson
    Verify that the motor is still working (listen closely while working the switch). If the motor is good, my money is on the actuator.
  8. #8 Re: Window Question
    Jun 2015
    I'll do that tomorrow then, I assume if I put my ear to the door panel, try to work the switch and I don't hear anything the motor is bad? If the motor is good, then I need something like: http://www.ebay.com/itm/1991-2010-GM...ZUOU8s&vxp=mtr correct?
  9. #9 Re: Window Question
    Mar 2014
    Tucson
    Quote Originally Posted by Kaiser Pontiac View Post
    Nope. More like this:
    http://www.ebay.com/itm/Window-Regul...-/281697987777
    I apologize. I called it an actuator. Meant to say regulator. The motors rarely go bad compared to regulators.
  10. #10 Re: Window Question
    Jan 2014
    AR
    Thats a broken regulator alright. Obvious in the new description of the trouble.
  11. #11 Re: Window Question
    Jun 2015
    Okay, thanks for the help guys!
  1. Power window question
    By gpbastard in forum General Tech Discussion
    Last Post: 11-04-2014, 11:20 AM
  2. Window question
    By komrad36 in forum General Tech Discussion
    Last Post: 08-03-2014, 09:17 AM
  3. Power Window Question
    By Bologna in forum General Tech Discussion
    Last Post: 10-14-2011, 06:05 AM
  4. QUESTION? intermittent window
    By SammyC1 in forum Shops and Community Heroes
    Last Post: 09-24-2009, 05:22 PM
  5. Window Regulator Question
    By cboth686 in forum General Tech Discussion
    Last Post: 04-16-2009, 09:41 PM
