Thread: Window Regulator Question
Results 1 to 4 of 4
cboth686 Window Regulator Question 04-12-2009, 07:50 PM
NaturallySmashed Re: Window Regulator Question 04-16-2009, 07:55 PM
Scimmia Re: Window Regulator Question 04-16-2009, 08:02 PM
Iron Indian Re: Window Regulator Question 04-16-2009, 09:41 PM
  1. #1 Window Regulator Question
    SE Level Member cboth686's Avatar
    Oct 2008
    Canada
    Alright, I'm losing my patience, my 3rd window regulator has gone on my car in the last 2 years.
    No way in hell I'm spending the $630 the Stealership wants from me for one. I already had my door panel off and managed to push the window back up, but if I find one at the junkyard how do I swap out the old one?
    Just unscrew the old one out? I'm not too sure what to do with the part that connects to window pane itself? Any tips or suggestions would be greatly appreciatted!
  2. #2 Re: Window Regulator Question
    Donating Users NaturallySmashed's Avatar
    Medford, NY
    yeah.. tape up the window.. pop the door off.. the door is 2 hex screws then start pulling straight back from the window panel and work your way around. then un-bolt the window regulator and motor.. then you might have to move the window down a little.. unscrew the window from the clips attatched to the regulator.. it's not that bad.
  3. #3 Re: Window Regulator Question
    GTP Level Member Scimmia's Avatar
    QCA, IA
    yeah, it's pretty straight forward. Sounds like they're the same POSes that they use in the Regal, I've gone through 6 so far. The window is held on the regulator by 2 bolts, the regulator itself is held on by 4 bolts, and the motor is held on by 3 bolts. I usually unbolt the window first, then regulator, then the motor, then reach in and unclip the electrical connection on the motor. Pull it out, stick the new one in, and reverse.
    2001 Buick Regal LS - Almost Stock
  4. #4 Re: Window Regulator Question
    Moore, Oklahoma
    I donno how you guys are going through so many regulators i've only put one in my car in 7 years.
    If you have an OReillys near you, buy the motor/regulator setup there, its got a Lifetime warranty and you can't beat that, especially with you guys destroying them alll the time......
    Shawn W. Larsen
  1. Cable on window regulator comes off [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 06-24-2015, 04:44 PM
  2. rear window regulator/motor install write up
    By ExpyGator in forum General Tech Discussion
    Last Post: 11-17-2009, 12:52 PM
  3. Re-running Window Regulator Cable..?
    By m0ng00se in forum General Tech Discussion
    Last Post: 03-30-2009, 03:20 PM
  4. 2-door window regulator compatibility
    By TurboTweak in forum General Tech Discussion
    Last Post: 11-16-2008, 02:02 AM
  5. Window motor and regulator - how difficult?
    By Coogles in forum General Tech Discussion
    Last Post: 05-07-2008, 09:14 PM
