Thread: Inner rear tire wear
Results 1 to 20 of 25
  1. #1 Inner rear tire wear
    California
    As the title states, I've been having a hell of a time with inner tire wear. After 2 sets of rear tires on my 07 Grand Prix (GT), I took the car into the dealership for an alignment. That was about six months ago. As soon as the car was aligned, I bought new tires and had them installed. Just yesterday I noted wear still on the inside edge. Since the car is newer, I am skeptic of worn out springs or struts, but at this point I'm tired of wasting money on tires every 8 months. I've owned the car for a little over 2 years now. Any ideas?
    Thanks,
    Camrin
  2. #2 Re: Inner rear tire wear
    GTP Level Member sdavis11b's Avatar
    Atlanta, GA
    Do you have subs or heavy loads in the trunk? And are you lowered? If so, it would throw the camber off in the back and you would need camber bolts.
    2004 GTP - TEP TRANS, INTERCOOLER, 3.0, AND PLENTY OF KR...
  3. #3 Re: Inner rear tire wear
    Waukesha, WI
    GM released a revised lateral arm kit for impalas, the newer ones had the same issue. i believe the kit would fit your car
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  4. #4 Re: Inner rear tire wear
    California
    Quote Originally Posted by sdavis11b View Post
    Nothing but the spare and odd and end crap back there.
    Quote Originally Posted by redlinepontiac View Post
    I came across that post while searching for an answer. Would that fall under warranty, or am I paying out of pocket for that?
    Thanks again guys (gals?),
    Camrin
  5. #5 Re: Inner rear tire wear
    Waukesha, WI
    i doubt that would be coverd under warranty, as far as i know the revised kits are only for impalas, but would fit a GP. so the stealership wouldnt warranty those parts to your car
    RayRay
    92 Turbo miata
    02 lexus is300
  6. #6 Re: Inner rear tire wear
    California
    Bringing this back from the dead. I'm still having tons of issues with the tire wear. I've had it aligned again, to no avail. I'm starting to think it might be the suspension in the rear based on some uneven wear when I first looked at the tires about a week ago, and the fact that the car has over 100k on it. The wear seemed to be a "wavey" pattern, but that has since evened out. Here are some pictures of the driver and passenger sides:
    Thanks again for the help. I'm extremely frustrated with the car in general, it's been nothing but one issue after another, but this is the biggest issue at the moment.
  7. #7 Re: Inner rear tire wear
    Donating Users
    Oct 2012
    lake city,fl
    could be ball joints ,i also had a wheel bearing that was so bad it caused tire wear just like that
  8. #8 Re: Inner rear tire wear
    Donating Users
    Oct 2012
    lake city,fl
    springs also wear as well so could be a few different things
  9. #9 Re: Inner rear tire wear
    id go back to the dealer and say thanks for fixing my alignment problem. as im sure you said, hey my back wheels are wearing on the inside........
  10. #10 Re: Inner rear tire wear
    There are no ball joints in the rear.
    Also, are those tires bald?
    Have you continued to buy the same tires?
  11. #11 Re: Inner rear tire wear
    California
    That place is a disgrace. They told me good luck, more or less.
    Let me make sure I'm understand you. You are replying to the guy that said that ball joints could be the issue, not making the statement that they look to be completely shot right?
    The edge is worn through the steel in some sections, the driver's side seems to be the worst. The rest of the tire has plenty of tread left.
    No, I've purchased three different sets of tires from three different places. This set seems to have lasted a shorter time than the others, but I don't know if that's because the tire brand or because whatever the issue is is getting worse.
    I've read so many threads here about this, some saying this is normal for these cars, some saying that it's alignment and that you need to specify that the toe needs to be fixed when you go in, some that its control arms, etc. I'm just tired of dealing with it. Is there a specific type of place to take it, or certain tests I can do to figure this out? I assumed the dealer would be the best pace, and obviously that was a joke. I went from owning a first gen Eagle Talon that had very few issues, and such a huge cult following that the ones I did have could be fix easy, to trying and scrounge for even the simplest answers for this car. This community seems to be great, but there isn't much for the older generations as far as I can find. Again, thanks for any and all help with this.
  12. #12 Re: Inner rear tire wear
    any alignment shop should see that wear and be able to figure out what parts are out, or old and worn out.
  13. #13 Re: Inner rear tire wear
    What you have might just be camber wear.
    Alignment with camber bolts might be the solution.
    Until you get it on an alignment rack that will provide you a print out, its all guessing.
    What I am questioning is how much is a lot of tread. I prefer actual numbers. Hence suggesting getting an alignment with numbers.
  14. #14 Re: Inner rear tire wear
    Did you ever rotate your tires or just run the backs until they needed changed? You need new tires on the rear right now before you have a blowout.
  15. #15 Re: Inner rear tire wear
    California
    There is a local place that I have read good things about, I'll check there.
    Those have been on the car for maybe 6 months. I know I need new tires, that's why I asked how to fix the issue.
  16. #16 Re: Inner rear tire wear
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    did they adjust the lateral arms at all? You get a print out if your alignment specs when you get it done?
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  17. #17 Re: Inner rear tire wear
    Aug 2008
    Hamilton, OH
    I'm also interested in this, as my '99 has the same problem. Of course, it also has 265k miles, so a few things are worn. I did replace the rear struts and springs. So any help with the likely worn components is appreciated.
    I will tell you this regarding front tires: If you are at a tire or aligment shop, and look on their chart of "typical problems" you won't find worn out balljoints listed. And that's the symptom of extreme wear on the inner edge of the tire. Most of the "out the door with more" tire places that include alignment will happily sell you new tires, realign, and never mention that your tires are vertically misaligned (toe). I had this happen on two sets of tires before figuring this out on my own, and had two blowouts.
    About the only solution is to go to an alignment shop. If you have friends who race, they'll know the places that know alignment. Go there, and tell them your problems, and they'll fix it.
    Does anyone have a rear suspension diagram they can share? I'm curious as to whats probably worn out on my car.
    thx,
    Sean
  18. #18 Re: Inner rear tire wear
    two lateral arms, one trailing arm, and a mcpherson strut.
    Trailing are full trailing, not semi trailing.
  19. #19 Re: Inner rear tire wear
    Aug 2008
    Hamilton, OH
    In other words, it's all worn out. 'Wonder how much in parts that is to fix?
  20. #20 Re: Inner rear tire wear
    Feb 2010
    TN
    I had the same problem replaced the lateral arms got it aligned and replaced a rim that was so slightly bent it washard to notice all was well
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Rear left tire locked up
    By mcrosswaith in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 11:17 AM
  3. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  4. Tire wear issue
    By tommygunz in forum Tires & Wheels
    Last Post: 08-13-2010, 08:07 AM
  5. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
