Thread: Inner rear tire wear
Results 1 to 20 of 25
  1. #1 Re: Inner rear tire wear
    Did you ever rotate your tires or just run the backs until they needed changed? You need new tires on the rear right now before you have a blowout.
  2. #2 Re: Inner rear tire wear
    California
    What you have might just be camber wear.
    Alignment with camber bolts might be the solution.
    Until you get it on an alignment rack that will provide you a print out, its all guessing.
    What I am questioning is how much is a lot of tread. I prefer actual numbers. Hence suggesting getting an alignment with numbers.
    There is a local place that I have read good things about, I'll check there.
    Those have been on the car for maybe 6 months. I know I need new tires, that's why I asked how to fix the issue.
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Rear left tire locked up
    By mcrosswaith in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 11:17 AM
  3. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  4. Tire wear issue
    By tommygunz in forum Tires & Wheels
    Last Post: 08-13-2010, 08:07 AM
  5. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
