Thread: Inner rear tire wear
Results 1 to 20 of 25
  1. #1 Re: Inner rear tire wear
    There are no ball joints in the rear.
    Also, are those tires bald?
    Have you continued to buy the same tires?
  2. #2 Re: Inner rear tire wear
    California
    id go back to the dealer and say thanks for fixing my alignment problem. as im sure you said, hey my back wheels are wearing on the inside........
    That place is a disgrace. They told me good luck, more or less.
    Let me make sure I'm understand you. You are replying to the guy that said that ball joints could be the issue, not making the statement that they look to be completely shot right?
    The edge is worn through the steel in some sections, the driver's side seems to be the worst. The rest of the tire has plenty of tread left.
    No, I've purchased three different sets of tires from three different places. This set seems to have lasted a shorter time than the others, but I don't know if that's because the tire brand or because whatever the issue is is getting worse.
    I've read so many threads here about this, some saying this is normal for these cars, some saying that it's alignment and that you need to specify that the toe needs to be fixed when you go in, some that its control arms, etc. I'm just tired of dealing with it. Is there a specific type of place to take it, or certain tests I can do to figure this out? I assumed the dealer would be the best pace, and obviously that was a joke. I went from owning a first gen Eagle Talon that had very few issues, and such a huge cult following that the ones I did have could be fix easy, to trying and scrounge for even the simplest answers for this car. This community seems to be great, but there isn't much for the older generations as far as I can find. Again, thanks for any and all help with this.
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Rear left tire locked up
    By mcrosswaith in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 11:17 AM
  3. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  4. Tire wear issue
    By tommygunz in forum Tires & Wheels
    Last Post: 08-13-2010, 08:07 AM
  5. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
