Thread: Inner rear tire wear
Results 1 to 20 of 25
  1. #1 Re: Inner rear tire wear
    Waukesha, WI
    GM released a revised lateral arm kit for impalas, the newer ones had the same issue. i believe the kit would fit your car
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  2. #2 Re: Inner rear tire wear
    California
    Quote Originally Posted by sdavis11b View Post
    Do you have subs or heavy loads in the trunk? And are you lowered? If so, it would throw the camber off in the back and you would need camber bolts.
    Nothing but the spare and odd and end crap back there.
    Quote Originally Posted by redlinepontiac View Post
    I came across that post while searching for an answer. Would that fall under warranty, or am I paying out of pocket for that?
    Thanks again guys (gals?),
    Camrin
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Rear left tire locked up
    By mcrosswaith in forum Brakes/Suspension/Chassis
    Last Post: 05-11-2013, 11:17 AM
  3. Rear tire wear
    By heavy duty in forum General Tech Discussion
    Last Post: 01-26-2011, 12:23 AM
  4. Tire wear issue
    By tommygunz in forum Tires & Wheels
    Last Post: 08-13-2010, 08:07 AM
  5. tire wear
    By izup69 in forum General Tech Discussion
    Last Post: 10-13-2009, 06:28 PM
