Thread: tire wear
Results 1 to 10 of 10
  1. #1 tire wear
    Destroys cars izup69's Avatar
    Iowa
    ok i got new tires about 6-7 months ago they are grooved for rain 2 deep grooves about 1 1/2 inch from the sidewall my front tires inside of that groove is wearin verry horibly prolly about 3/10th tred left on frnt but outside the grooves at least 7/10th tred left the rear tires are perfect i checked press to make shure not over inflated and they are perfect pres. cant figure out why its wearin so bad just inside the groove like i said outside of the groove still good ill go take some picks and post em along with this
  2. #2 Re: tire wear
    Donating User Odi's Avatar
    Chicago South Suburbs
    How long ago did you do your alignment? Sounds like you need it.
  3. #3 Re: tire wear
    Iowa
    yeh i noticed i posted in rong sec after i already posted it oops lol i had my alignment done about 40k miles ago when i had trans replaced
  4. #4 Re: tire wear
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    Your toe sounds like its off by a degree or so. Get an alignment and rotate the tires
    Maybe even pay the extra money and have the wheels re-balanced. You'll get another 35-45k miles out of the rear (would be front after a rotation) tires.
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  5. #5 Re: tire wear
    Iowa
    yeh they have a 80k mile warranty on em just dont have the 60 bucks atm to get a alignment done
  6. #6 Re: tire wear
    Moore, Oklahoma
    40k since your last alighnment? Yeah, you need another one for sure. Sounds like your camber is off to me...
    Shawn W. Larsen
  7. #7 Re: tire wear
    Minnesota, Eh?
    Quote Originally Posted by Iron Indian View Post
    Could be camber, but at the rate they're wearing, sounds more like a toe issue. Might be a combination of both though. It depends on whether the tread is feathered or not.
  8. #8 Re: tire wear
    GT Level Member skidoojames151's Avatar
    seattle
    if it were camber an alignment shop couldnt do much about it then...there is no adjustment on these cars
  9. #9 Re: tire wear
    Nov 2008
    Searcy,Arkansas
    Sounds like they are wearing like mine did. If you look under tires you should see pictures of my old tires! they was VERY bad! and my back ones! I know they said I needed alignment bad!!
  10. #10 Re: tire wear
    Gainesville
    Coming from someone who works on tires everyday. That definitely sounds like an alignment issue. Get that taken care of before rotating your tires, or you'll eat up the tred on your good ones. Unfortunately mileage warranties don't cover mechanical wear such as alignment issues, but if you get it taken care of ASAP you might be able to receive some credit on that tire.
  1. Tire wear on inside edges in back
    By nlinesk8s in forum Brakes/Suspension/Chassis
    Last Post: 07-04-2014, 11:43 AM
  2. Dashboard Wear. Help.
    By Traeger2591 in forum Visual/Body Modifications
    Last Post: 07-24-2009, 12:58 PM
  3. tire rack ? about this tire
    By GTPJOE90 in forum Tires & Wheels
    Last Post: 03-09-2009, 09:12 PM
  4. Blower wear
    By Sabrewings in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-20-2009, 10:18 PM
  5. Spare tire well
    By JCG's-GTP in forum Audio, Security & Visual Electronics
    Last Post: 04-25-2008, 10:08 AM
