Quote Originally Posted by Oxfire View Post
Why were motor/tranny mounts just mentioned? You should get those switched up and Im willing to bet it will fix your issue.
First post:
Quote Originally Posted by Mr D View Post
Everytime I replace a part, driving/handling improves, but it is still not "right". In the last couple monthes I have New; KYB Excell G struts in HTM c/o, NAPA axles, DEA solid M&T mounts
Most of his problem was the inner tie rod. Do you think the solid mounts could be the cause of the small amount of vibration he has left?
