You guys are awesome, really. Properly connected breather tube to both boots and squeak when turning is gone. Seems like all plunks, knocks, et al are finally gone. Still vibrates on acceloration.... take what I can get. I decided I'm going to leave left side alone for now and return those parts.
Under car for almost hour and noticed wet spot where rt cv axle enters trans. its not bad enough to drip, i have left cardboard under it over night twice since changing axles, but definately moist where axle meets trans, down to the corner of trans fluid pan. When I 1st saw it I thought maybe pan leaked, but moisture seems to be from above and making its way down to edge of pan. When I get fed up with vibration maybe I'll swap out remanf napa axle? Right now, I'm ready for another alignment and to drive a little.
Thanks again, really!
