sorry,
got outter tie rod and boot off and tool DOES NOT FIT INNER TIE ROD ON CAR. inner tie rod on car has white plastic sleeve, and flattened part behind ball joint that tool fits over is much thinner than replacement. I'M STUCK.
Called pepboys, and they rent tool i already have.
Scottydoggs, if you're out there, or anyone, can you give me manuf & part # for tool in picture posted?
or if anyone has run into same issue, tool they used to get what I assume is OE inner tie rod off.
Again, greatly appreciated!
