Thread: Drilled/Slotted or both?
Results 1 to 20 of 29
  1. #1 Drilled/Slotted or both?
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    hey i had a question to those out there that know their rotors...i want to upgrade mine and i want to look for the best for the best price...i was looking at the rotors on pfyc.com...any inputs?
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: Drilled/Slotted or both?
    Oklahoma
    Well I am no fan of drilled rotors. Slotted are okay as it serves a function. But I have seen the drilling cause stress fractures.
  3. #3 Re: Drilled/Slotted or both?
    TDCRacing
    Guest
    Go on ebay to get some better prices...I think there is a thread in this section on the ebay ones...if you need help finding it leme know
  4. #4 Re: Drilled/Slotted or both?
    Saraland Alabama
    same here, drilling is for looks, and causes a stress riser unless chamfered. For things that involve saving my life and my families lives I buy from people I can trust, never would I buy a brake part off ebay, if something happens your screwed as they don't have liability insurance like a legitimate company does
  5. #5 Re: Drilled/Slotted or both?
    TDCRacing
    Guest
    What about a company that is just on ebay to help promote sales?...like summitracing...would you never buy a brake part from summit on ebay? just because it's on ebay doesent mean it's crap...I have a set of drilled and slotted rotors from rotorworks on ebay and they have been no trouble at all...i belive r1concepts (the company in that thread i mentioned) has his own store but is also on ebay....and many people on here have his rotors on there cars right now....And i'm positive pfyc doesent make those rotors...they may even get them from some of the same ppl off of ebay...not trying to start anything...just giving a different side of the story is all....
  6. #6 Re: Drilled/Slotted or both?
    GT Level Member TurboKent's Avatar
    Woodward, OK
    i'll eventually be getting a set of the EBC 3GD Sport Rotors, slotted and dippled instead of drilled. Then a set of yellow stuff pads.
    EBC Brakes - Home of the worlds largest range of brake products - Automotive Brake Rotor Information
  7. #7 Re: Drilled/Slotted or both?
    Wichita, KS
    Yes, slots serve a purpose, but unless you know your getting a good quality set, stay away from drilled. Dimpled rotors are fine to get.
    I have both, drilled, and slotted on my car front and rear. I love them, and haven't had any problems with them.
    ~F~
  8. #8 Re: Drilled/Slotted or both?
    PA
    I agree that I would stay away from drilled rotors. Some may be fine. Some may not. Don't chance it.
    I have powerslots on my car cause I got them for cheap. But my next set I would consider R1 Concepts from the web.
    2001 GSE
  9. #9 Re: Drilled/Slotted or both?
    Fayetteville, NY
    ok where could i look at dimpled and slotted rotors?...nice rims by the way GR8
  10. #10 Re: Drilled/Slotted or both?
    Saraland Alabama
    Quote Originally Posted by TDCRacing View Post
    you must realize that 99% of the "companies" on ebay are guys in their basements, there is a reason that a bunch of companies are putting disclaimers on their websites telling you if it came from ebay it has no warranty. I don't buy brake parts from summit usually either simply because I don't like the prices and I refuse to wait for parts I can buy local for the same amount or less
  11. #11 Re: Drilled/Slotted or both?
    TDCRacing
    Guest
    Quote Originally Posted by archemedes View Post
    You know you are probably right about the basement thing....but just from my personal experience i have never seen a brake part actually fail...as far as a rotor goes...i'm not saying it is not impossible...Generally these basement company's are using the same equipment to drill and slot these rotors as powerslot ect... are.....I guess in the end you get what you pay for lol
  12. #12 Re: Drilled/Slotted or both?
    Saraland Alabama
    they don't make them, I can buy rotors for next to nothing from china, and I have seen some fail catastrophically (as in disintegrate from a hard stop then hitting a puddle) the drilled rotors crack very often, the problem is few shadetrees look at the rotor surface when doing brakes
  13. #13 Re: Drilled/Slotted or both?
    Fayetteville, NY
    ok...lol...anyone know where i could order slotted and "dimpled"?
  14. #14 Re: Drilled/Slotted or both?
    Wichita, KS
    You can buy slotted and dimpled rotors from EBC Rotors is the name of the company.
    Googled EBC and hit these two places:
    and
    AJ-USA.com - Direct Source Outlet for Performance Parts and Accessories
    ^ this is the place where my friend bough his through for his GTP. Yes, they have stock, and he runs F-Body front brakes, so he ordered those for his application.
    To extend the life of any "performance" rotor, be sure to correctly season them as soon as they are installed before you have the chance to do some really hard braking on them. That will extend their life like you wouldn't believe.
    ~F~
  15. #15 Re: Drilled/Slotted or both?
    Fayetteville, NY
    ok thanks GR8!
  16. #16 Re: Drilled/Slotted or both?
    Wichita, KS
    No problem.
    Here is some info on rotor seasoning:
    Baer Brake Systems -- Braking 202 -- "Rotor Seasoning" -- Performance you can See!
    ~F~
  17. #17 Re: Drilled/Slotted or both?
    Oklahoma
    Great information Farns. Thanks for posting that up.
  18. #18 Re: Drilled/Slotted or both?
    Wichita, KS
    No problem G.
    ~F~
  19. #19 Re: Drilled/Slotted or both?
    Fayetteville, NY
    hey GR8 i was looking at that EBC brake site, how do you get to the slotted and dimpled rotors and prices?
  20. #20 Re: Drilled/Slotted or both?
    Wichita, KS
    EBC is the maker of them, and normally you, the customer, cannot buy direct from them, thats why I gave you the other link:
    Buy from them, they are the seller from the supplier.
    ~F~
