Thread: Drilled/Slotted or both?
Results 1 to 20 of 29
  1. #1 Re: Drilled/Slotted or both?
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    ok...lol...anyone know where i could order slotted and "dimpled"?
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: Drilled/Slotted or both?
    Wichita, KS
    You can buy slotted and dimpled rotors from EBC Rotors is the name of the company.
    Googled EBC and hit these two places:
    EBC Brakes - Home of the worlds largest range of brake products
    and
    AJ-USA.com - Direct Source Outlet for Performance Parts and Accessories
    ^ this is the place where my friend bough his through for his GTP. Yes, they have stock, and he runs F-Body front brakes, so he ordered those for his application.
    To extend the life of any "performance" rotor, be sure to correctly season them as soon as they are installed before you have the chance to do some really hard braking on them. That will extend their life like you wouldn't believe.
    ~F~
