Thread: Drilled/Slotted or both?
Results 1 to 20 of 29
  1. #1 Re: Drilled/Slotted or both?
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    hey GR8 i was looking at that EBC brake site, how do you get to the slotted and dimpled rotors and prices?
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: Drilled/Slotted or both?
    Wichita, KS
    EBC is the maker of them, and normally you, the customer, cannot buy direct from them, thats why I gave you the other link:
    AJ-USA.com - Direct Source Outlet for Performance Parts and Accessories
    Buy from them, they are the seller from the supplier.
    ~F~
  3. #3 Re: Drilled/Slotted or both?
    TDCRacing
    Guest
    check summit also ...they sell them too
