Thread: Drilled/Slotted or both?
Results 1 to 20 of 29
  1. #1 Re: Drilled/Slotted or both?
    GT Level Member GP2003GT's Avatar
    Fayetteville, NY
    ok thanks GR8!
    http://www.cardomain.com/ride/2556536 NKG Iridium Plugs, 8mm Spiro Wires, ZZP Reprogrammed PCM, ZZP 3" full cat, ZZP Ceramic Coated Ported Manifolds, ZZP HV3, ZZP HVTB, ZZP ER Ratio Rocker Arms, ZZP Drilled 180* Thermostat, MotorSports Performance Intake, Reptile's IAT and dezldave tuned
  2. #2 Re: Drilled/Slotted or both?
    Wichita, KS
    No problem.
    Here is some info on rotor seasoning:
    Baer Brake Systems -- Braking 202 -- "Rotor Seasoning" -- Performance you can See!
    ~F~
