Thread: What is lost with new hu?04+
Results 1 to 20 of 29
  1. #1 What is lost with new hu?04+
    indiana
    Is it just door chimes ?
  2. #2 Re: What is lost with new hu?04+
    Omaha, NE
    If you buy the expensive connector, you lose nothing as far as I know, but that one is $120.
    If you buy the cheap connector you will lose your door chimes, and the date on your dic, that's all I've noticed anyway.If you have monsoon or onstar you'll probably lose those too. and I paid $25 after tax. Its a metra 97-2003 that I used.
    And for refernce it can be a pain finding a source to run a remote wire on some 04+
  3. #3 Re: What is lost with new hu?04+
    indiana
    What do you mean about the remote wire. Remote wire for what?
  4. #4 Re: What is lost with new hu?04+
    Omaha, NE
    Ignition switched power. For whatever reason it's not in the factory harness, so we have to find it elsewhere. I have mine wired to a switch because all of my fuses in my 04 were constant. I haven't tried my 05 yet.
  5. #5 Re: What is lost with new hu?04+
    indiana
    Wow wtf gm. I seriously don't even wanna do the install myself now might just take it to an audio shop
  6. #6 Re: What is lost with new hu?04+
    Omaha, NE
    Other members have had sucess running an add a fuse onto their passenger side fuse box with an ignition switched fuse.
    Or another option is that there is supposed to be an ignition switched power drop under the drivers side dash IIRC.
    A shop will most likely make you buy the $120 harness on top of their install price, so that could be an expensive route to go.
  7. #7 Re: What is lost with new hu?04+
    indiana
    Yea I know. Iv never taken a car to a shop for installs. Always done them myself but this seems like a lot of work that I don't wanna do
  8. #8 Re: What is lost with new hu?04+
    Omaha, NE
    Nah, its a basic wire harness install once you find the ignition switched source.
  9. #9 Re: What is lost with new hu?04+
    indiana
    What about the module. I was looking at it and it looks like a regular wire harness so does the stereo harness just splice into that?
  10. #10 Re: What is lost with new hu?04+
    Feb 2009
    Virginia
    They don't have an ignition switched source because they utilize the RAP system.
    GM’s R.A.P system and an amp, tcss - Page 2
    I believe I used a GMOS-02 in my install
    11 is louder than 10!
  11. #11 Re: What is lost with new hu?04+
    Omaha, NE
    That explains that. I can't believe all my searching didn't turn that up.
    Thanks I800!
  12. #12 Re: What is lost with new hu?04+
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    i had this same question. thanks guys. just one thing im confused on is how do you connect the 12v?
    EDIT: you can get the metra 70-2003 on amazon for a penny
  13. #13 Re: What is lost with new hu?04+
    GTP Level Member simbah's Avatar
    Lala land
    I used ht GMOS 01 on my 06 and I had the Monsoon and no Onstar. My intentions were to install a different amp and speakers anyhow so the GMOS01 worked just fine for me, as a matter of fact I wired the chimes to come out the center speaker and not the front left. The only other loss was the date function on the DIC and I don't miss it at all.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  14. #14 Re: What is lost with new hu?04+
    SE Level Member tu8i1o7's Avatar
    Siuox Falls, SD
    I would highly suggest you utilize the gmos 02 interface. It's basically plug and play with the head unit(no need to search for the 12v accy. RAP wire), and you can keep the chimes. The problem with the accy. to the radio is GM uses a 5v relay for the radio. Car turns on, sends 5v to the relays, and switches on the RAP system. Regardless of what you do, as soon as you remove the stock hu, you lose the date in the dic. Another one of those things GM did, that data is stored in the non volatile memory in the hu. If you do plan on just using a harness the 12v RAP wire is behind the glove box, accessible from the door jam panel, it's an orange wire. Hope this helps.
  15. #15 Re: What is lost with new hu?04+
    utah
    I lost my door chime..but still have my date
  16. #16 Re: What is lost with new hu?04+
    indiana
    Damn that thing is almost 200 bucks. But it works?
  17. #17 Re: What is lost with new hu?04+
    Siuox Falls, SD
    Sorry, i was mistaken, its the gmos-04. Yeah, it's pretty pricey. You can find them for $100ish online. It really is the easiest and most functional setup though, worth every penny. I have one that is used and doesn't have the instructions I could sell you for cheap. PM me if interested.
  18. #18 Re: What is lost with new hu?04+
    Feb 2009
    Virginia
    Quote Originally Posted by boostedcompg View Post
    How'd you pull that off? What wiring harness are you using?
  19. #19 Re: What is lost with new hu?04+
    Lala land
    That is a GOOD QUESTION
  20. #20 Re: What is lost with new hu?04+
    utah
    I don't know. Had a shop do it. I could call my buddy and ask.
  1. im lost!
    By adamLG in forum General Tech Discussion
    Last Post: 06-21-2011, 05:39 AM
  2. lost mpg
    By angie in forum General Tech Discussion
    Last Post: 12-20-2010, 10:59 PM
  3. car lost its up
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2010, 10:14 PM
  4. im lost here
    By sven101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 04:07 PM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
