Thread: No AM Radio since After Market install
Results 1 to 9 of 9
  1. #1 No AM Radio since After Market install
    SE Level Member Zaniac's Avatar
    Winnipeg
    Hey Guys,
    I installed the Pioneer AppRadio in my '04 GP and everything works great except no AM radio (Morning Sports Radio). FM works fine. I am sure it has something to do with the powered antenna and something needs to be spliced to voltage but have no idea which wire it is? Any help would be appreciated.
    D
  2. #2 Re: No AM Radio since After Market install
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    I have had the same problem with both of my aftermarket radios, I get a little recepion but not much. I think it might just be how it is
  3. #3 Re: No AM Radio since After Market install
    Winnipeg
    The weird part is as soon as I turn the car off, I get reception, albeit not great. As soon as I turn the car on, I get absolutely none on AM which leads me to think it has something to do with the antenna but not sure. It's not a huge deal, I can use Tune-in on my iPhone to listen to AM but would rather let the radio do it.
  4. #4 Re: No AM Radio since After Market install
    YOu have a powered antenna?
    Hey..maybe you should tell us what year/model you have
  5. #5 Re: No AM Radio since After Market install
    Winnipeg
    I guess "Powered Antenna" may be the wrong choice of words. I heard that the GP's (I have a 2004 GT1) have a powered/amplified antenna's that requires a power source to boost the signal? Simply plugging the Antenna cable into the After Market HU doesn't amplify the signal enough to get AM radio is what I am thinking?
  6. #6 Re: No AM Radio since After Market install
    GT Level Member 2dee11's Avatar
    Nov 2011
    Decatur
    I also noticed after a month or two of installing my pioneer I had no AM
  7. #7 Re: No AM Radio since After Market install
    GT Level Member Shiftingshaddow's Avatar
    KC
    you have to install an aftermarket antenna.
    http://www.grandprixforums.net/2001-...res-76657.html
    4th pic from the top shows it on the back glass
    2001 GTP Special Edition
    ZZP DP with Cat, Open Cone Intake, ZZP 1.0 PCM, 3.4 pulley, AL 104s, Rocker Panel Delete.....
  8. #8 Re: No AM Radio since After Market install
    Oct 2011
    huntley
    Alright well then where did you get that antenna from?
  9. #9 Re: No AM Radio since After Market install
    KC
    it came on the car. i tried a quick google search but didn't come up with anything. i had this same head unit in two other gtps and had the signal problem. my buddy has a monte and he had that little antenna on his window, too. i don't know if its a signal booster or another antenna. it is mounted on the back window and the wire goes through the glass. i don't know where it runs from there but it doesn't go into the dash where the stereo is. anyway, i get am radio and all the stations and hd stations come in clearly with that little doodad.
    go to a car audio shop or to best buy or something and ask.
  1. NEED HELP! with 2004 Grand Prix after market radio install.
    By Trentonio in forum Audio, Security & Visual Electronics
    Last Post: 06-08-2016, 09:08 PM
  2. best after market radio harness.
    By ham4864 in forum Audio, Security & Visual Electronics
    Last Post: 12-05-2010, 01:45 AM
  3. After market amp to Bose amp install
    By kolman in forum Audio, Security & Visual Electronics
    Last Post: 05-01-2010, 11:50 AM
  4. Heads Up display, after Market Radio & Mp3s??
    By Talon in forum Audio, Security & Visual Electronics
    Last Post: 06-21-2009, 01:20 PM
  5. After market radio ?
    By GAFF in forum Audio, Security & Visual Electronics
    Last Post: 01-25-2009, 01:17 PM
