Thread: big 3 upgrade ????
Results 1 to 12 of 12
  1. #1 big 3 upgrade ????
    GTX Level Member Doug 97 gtp's Avatar
    Sep 2011
    palm harbor florida
    ok so i made a new thread that got locked i understand what the big 3 upgrade is... i was asking to see pictures of people that have done it to a grand prix. so if you have any pics please feel free to post away
    1997 GTP . repainted in jet black with blue pearl. rebuilt motor
    with vs cam ported heads and blower.
  2. #2 Re: big 3 upgrade ????
    srs.
    Google
  3. #3 Re: big 3 upgrade ????
    London Ont, Canada
    have you even searched on here??? theres tons of info on it, not everyone takes pics but its all self explanatory
  4. #4 Re: big 3 upgrade ????
    I don't understand why you want pics.
  5. #5 Re: big 3 upgrade ????
    Sep 2011
    palm harbor florida
    because im a visual person. i understand the big 3 like i said before. i just want to see how people have done it on these cars.
  6. #6 Re: big 3 upgrade ????
    Feb 2009
    Virginia
    Generally speaking...it's not necessary for our vehicles. Do you have maintenance concerns? Want to replace because the wires are old/corroded?
    I don't care to get involved with arguments anymore. But there is PLENTY OF THREADS concerning this already. Pictures?...I dunno. But most consider it so simple pictures aren't needed. There's a picture of somebody's spaghetti in this thread...
    ClubGP Message Forum troubleshooting
    11 is louder than 10!
  7. #7 Re: big 3 upgrade ????
    Feb 2009
    Virginia
    I'm trying to connect dots....2ohm 15" sub w/Rockford Prime that puts out "1kw" at 2ohms.
    Do not need "big 3 upgrade." Also, if you want more output then design a nice box. I don't care to talk about boxes either, sorry. Google pwk designs.
  8. #8 Re: big 3 upgrade ????
    Feb 2009
    Virginia
    Found quite a bit of info using google + grand prix + big three...
    Quoting myself from this thread....
    Grand Prixs Of North America • View topic - The Big 3, Everything You Wanted to Know + DIY
    Quote Originally Posted by I800C0LLECT
    If you have a daily driver system Big 3 really doesn't help. Personally, I only recommend Big 3 if you grab an h.o. alt. Otherwise, my system running full tilt probably only uses ~25 amps at most WITH MUSIC. My amps push a total of about 1800 watts using a/b power supplies according to marketing. The op also mentions how he was getting flak from gpf.net. I can't talk for anybody else but I'm contributing the same information everywhere I go. I even have a thread here that explains why big 3 is nothing more than trendy when using stock alternators.
    c_k_115: You can upgrade that cable. However, make sure your ground is the same or better.
    -- Sun Aug 29, 2010 12:31 pm --
    Some cheap reading about "Big 3"
    An opinion about Alt. loads...
    First thing anybody should do if they have issues with "dimming" is make certain they have GOOD grounds. Alternators don't have the capacity to fluxuate THAT quickly in order to respond to a "dim". If you have an issue with low output from your alternator that dim isn't for a split second...it lasts until that load is removed. i.e. power windows, rear defroster, etc. Once that "load" is turned off lights will resume normal function.
    -- Sun Aug 29, 2010 12:32 pm --
    An example of WHEN to use Big 3.
    -- Sun Aug 29, 2010 12:39 pm --
    This makes me smile
    Bottom line...Big 3 isn't necessary in our vehicles UNLESS you need an H.O. alternator which would be specific to your application of speaker theory. Grounds are most important. That charging wire is only as good as the grounds that are complimenting.
    If people come back and say "MY WINDOWS ROLL UP FASTER!!!".....what variables are inherently related to the electric motor working harder? If you can't answer then don't tell me emphatically that the "Big 3" is important. It's a trend outside of specific goals, which most individuals don't adopt.
    -- Sun Aug 29, 2010 7:40 pm --
    Sorry...I felt like adding another....
    Here's another thread disputing "Big 3"
  9. #9 Re: big 3 upgrade ????
    Feb 2009
    Virginia
    One of my favorite quotes...
    Quote Originally Posted by gijoe View Post
    Maybe in theory, but when it comes to hours of work, and money spent on new wire, I would only recommend it if necessary.
    You may lower the resistance, but is the resistance already high enough to cause a voltage drop? And is that voltage drop big enough to make an audible difference?
    "Big 3" should be changed to "upgrade grounds and don't **** with the alternator to battery cable...unless you've upgraded your alternator"
  10. #10 Re: big 3 upgrade ????
    Feb 2009
    Virginia
    Gonna spam some more...BUT THIS ONE HAS AN AWESOME VIDEO!!!!!
    TDIClub Forums - View Single Post - Stereo people. Anyone upgrade big 3 here?
    The video...
  11. #11 Re: big 3 upgrade ????
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Try inputting "big 3" into the forum search engine and see what happens.
  12. #12 Re: big 3 upgrade ????
    Quote Originally Posted by I800C0LLECT View Post
    The video...
    this is the best way to make cables by far, only thing is tape sucks, you want to use shrink tubes over the metal to the rubber insulation in the cable. as dry wire can still get in and under the insulation and kill the cable over time.
  1. Headlight and FogLight Upgrade (to upgrade to HID or not?) Please Help???
    By Michigan04GrandPrix in forum Visual/Body Modifications
    Last Post: 04-20-2012, 12:53 PM
  2. upgrade help
    By 08ROLLER in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-25-2011, 09:03 PM
  3. HUD Upgrade?
    By donnie98gtp in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2010, 10:25 AM
  4. First upgrade for GTP ?
    By MikeZirpola in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2009, 08:20 PM
  5. Next Upgrade?
    By 04gpking85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2008, 07:39 PM
