Thread: What is lost with new hu?04+
Results 1 to 20 of 29
  1. #1 Re: What is lost with new hu?04+
    SE Level Member tu8i1o7's Avatar
    Siuox Falls, SD
    I would highly suggest you utilize the gmos 02 interface. It's basically plug and play with the head unit(no need to search for the 12v accy. RAP wire), and you can keep the chimes. The problem with the accy. to the radio is GM uses a 5v relay for the radio. Car turns on, sends 5v to the relays, and switches on the RAP system. Regardless of what you do, as soon as you remove the stock hu, you lose the date in the dic. Another one of those things GM did, that data is stored in the non volatile memory in the hu. If you do plan on just using a harness the 12v RAP wire is behind the glove box, accessible from the door jam panel, it's an orange wire. Hope this helps.
  2. #2 Re: What is lost with new hu?04+
    indiana
    Damn that thing is almost 200 bucks. But it works?
  1. im lost!
    By adamLG in forum General Tech Discussion
    Last Post: 06-21-2011, 05:39 AM
  2. lost mpg
    By angie in forum General Tech Discussion
    Last Post: 12-20-2010, 10:59 PM
  3. car lost its up
    By sca555 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-21-2010, 10:14 PM
  4. im lost here
    By sven101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 04:07 PM
  5. I'm new! And lost!!
    By lindzabu in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-24-2008, 07:32 PM
