Yeah, that's the one.
Did you unhook the pcm when doing the trans?
Reason I'm not sure it's security is because most of these cars and I know 02 is this way.. they'll prime the fuel pump, start and die when the pump isn't turned on the for the theft.
Try jumping the starter with a screw driver...from the hot battery cable to the purple starter soleniod wire. The engine should crank over.
