Thread: At wits end... Security problem?
Results 1 to 9 of 9
  1. #1 Re: At wits end... Security problem?
    Oct 2011
    Chicago IL
    It does not turn over, nothing. Turn the key and I hear a relay click (Or something similar) and then just have the security flash over and over.
    I did hook up the two connectors to that sensor. If its the one under the shifter linkage.
  2. #2 Re: At wits end... Security problem?
    Yeah, that's the one.
    Did you unhook the pcm when doing the trans?
    Reason I'm not sure it's security is because most of these cars and I know 02 is this way.. they'll prime the fuel pump, start and die when the pump isn't turned on the for the theft.
    Try jumping the starter with a screw driver...from the hot battery cable to the purple starter soleniod wire. The engine should crank over.
  3. #3 Re: At wits end... Security problem?
    Oct 2011
    Chicago IL
    Well I forgot to hook up the ground...
    Car now works and starts but for some reason the security light flashes over and over until a certain amount of time before turning off. Car runs great though.
    One thign that I noticed is that the Tach is no longer working. Gonna check the fuses but any suggestions?
  1. At Wits End (97 GP GT)
    By ThaYeti in forum General Tech Discussion
    Last Post: 08-26-2011, 09:17 PM
  2. security light
    By Myprixxx in forum General Tech Discussion
    Last Post: 05-12-2010, 05:08 PM
  3. Security
    By Bob8205 in forum Introductions/Noob Questions
    Last Post: 08-31-2009, 06:43 PM
  4. OEM Security LED
    By Lion29GTP in forum Audio, Security & Visual Electronics
    Last Post: 07-04-2009, 01:47 AM
  5. factory security system problem
    By TJs97 in forum Audio, Security & Visual Electronics
    Last Post: 03-14-2009, 12:44 AM
