Quote Originally Posted by Carlos773 View Post
Yep their all hooked up. I will double check to see if their nice and tight. I found what seems to be the vats reset, The whole 10 mins in on position and then back, I will also try this.
If all fails then the pcm will be going out to get vats tuned out.
What is this process? I also just swapped my trans but I forgot to hookup the ground cable at the trans as pictured and tried to start it. Now it just blinks all the time.
