Thread: no sound?? help please...
Results 1 to 7 of 7
  1. #1 no sound?? help please...
    SE Level Member hoagieman26's Avatar
    Oct 2011
    Garden City, Mi
    i have the 2002 gp 40th anniversary edition with the bose eight speaker system. recently, the front drivers side door speaker and the tweeter in the a pillar dont work. im only good with home stereos so id like some help...thanks!
  2. #2 Re: no sound?? help please...
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    Have you checked all the fuses and have you checked the resistance of the speakers?
  3. #3 Re: no sound?? help please...
    SE Level Member Lionel's Avatar
    Moncton N.B.
    I'd grab a voltmeter and check if the speakers are getting power. if they are you have a speaker problem. I recently fixed my driver's side speaker that stopped working, the wires going to it had power,
    i just re-soldered the wire that goes from the cone to the connectors. the fact that your tweeter and speaker stopped working is strange though.
  4. #4 Re: no sound?? help please...
    Oct 2011
    Garden City, Mi
    the front door and the a pllar tweeter are on the same channel...i believe, so i thank it has something to do with the stereo
  5. #5 Re: no sound?? help please...
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by hoagieman26 View Post
    It is defiantly possible to only have one channel go out on a stereo, and the tweeter and midrange are on the same channel in our GP's. A could of things I would check though, like everyone else said, make sure your getting power to your speakers, easiest way is to grab a speaker and test it, or just use a millimeter. If you rant getting power, then follow the wires back to the stereo and make sure that harness is secured, maybe even re-seat it. If you are, which is a good thing, check the connections between each speaker and the wires, if its the speakers, buy better ones!
    Best of luck!
    Infinity all around.
  6. #6 Re: no sound?? help please...
    Aren't both items in the door? Which would mean that they both are fed by the same two wires that pass through the door boot? Which would then lead us to wonder if over the years they haven't broken?
    It's pretty common . Actually I have an 02 that I need to check into. Same issue.
  7. #7 Re: no sound?? help please...
    SE Level Member deathjunior's Avatar
    Missouri
    Wouldn't surprise me if the amp outputs were having issues. My Grand prix seems to have issues with the drivers side door channel as well. Its not that they don't work its that I have to turn them up a bit for the amp to fully power them then turn it back down to listening levels otherwise its as if the left side just doesn't recieve as much power as the right. I have the same Bose system you do (with a bit of modifications, hertz dieci's up front for now and an RE SR sub and amp outback). Its also an issue that happens on my TEAC home amp from the late 80's so its no surprise to me. Besides bose amps going away soon anyway. I feel like since its a class A/B amp it just has to warm up its circuits a bit, but it could be a connection in the amp slowing wearing down until it ends up like yours.
  1. name that sound
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2010, 11:46 PM
  2. new to this sound...?
    By X97prixX in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2009, 01:52 PM
  3. This sound right?
    By BwolfGT in forum General Tech Discussion
    Last Post: 09-28-2009, 12:29 AM
  4. what does a bad TC sound like?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-07-2009, 08:43 PM
  5. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
