the front door and the a pllar tweeter are on the same channel...i believe, so i thank it has something to do with the stereo
It is defiantly possible to only have one channel go out on a stereo, and the tweeter and midrange are on the same channel in our GP's. A could of things I would check though, like everyone else said, make sure your getting power to your speakers, easiest way is to grab a speaker and test it, or just use a millimeter. If you rant getting power, then follow the wires back to the stereo and make sure that harness is secured, maybe even re-seat it. If you are, which is a good thing, check the connections between each speaker and the wires, if its the speakers, buy better ones!
Best of luck!
Aren't both items in the door? Which would mean that they both are fed by the same two wires that pass through the door boot? Which would then lead us to wonder if over the years they haven't broken?
It's pretty common . Actually I have an 02 that I need to check into. Same issue.
