Thread: no sound?? help please...
Results 1 to 7 of 7
  1. #1 Re: no sound?? help please...
    GT Level Member chamilton89's Avatar
    Columbus, Ohio, United States
    Quote Originally Posted by hoagieman26 View Post
    the front door and the a pllar tweeter are on the same channel...i believe, so i thank it has something to do with the stereo
    It is defiantly possible to only have one channel go out on a stereo, and the tweeter and midrange are on the same channel in our GP's. A could of things I would check though, like everyone else said, make sure your getting power to your speakers, easiest way is to grab a speaker and test it, or just use a millimeter. If you rant getting power, then follow the wires back to the stereo and make sure that harness is secured, maybe even re-seat it. If you are, which is a good thing, check the connections between each speaker and the wires, if its the speakers, buy better ones!
    Best of luck!
    Infinity all around.
  2. #2 Re: no sound?? help please...
    Aren't both items in the door? Which would mean that they both are fed by the same two wires that pass through the door boot? Which would then lead us to wonder if over the years they haven't broken?
    It's pretty common . Actually I have an 02 that I need to check into. Same issue.
  1. name that sound
    By jdmgtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-16-2010, 11:46 PM
  2. new to this sound...?
    By X97prixX in forum Brakes/Suspension/Chassis
    Last Post: 11-03-2009, 01:52 PM
  3. This sound right?
    By BwolfGT in forum General Tech Discussion
    Last Post: 09-28-2009, 12:29 AM
  4. what does a bad TC sound like?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-07-2009, 08:43 PM
  5. what should i do to get this sound?
    By bhrfpa11 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-16-2008, 07:22 PM
