Thread: Bench Test Driver Information Center (DIC)
Results 1 to 20 of 25
  1. #1 Bench Test Driver Information Center (DIC)
    SE Level Member jejensen's Avatar
    Iowa
    Does anyone know how to connect a digital Driver Information Center (DIC) from a 99 GT to a 12VDC power source to check if the lights and LCD are functional? It has a 24 pin connector on the back plus I have the mating plug with flying leads.
  2. #2 Re: Bench Test Driver Information Center (DIC)
    why two threads?
  3. #3 Re: Bench Test Driver Information Center (DIC)
    Iowa
    Just trying to determine if the DIC I have is ok. The dash panel is a pain to remove so thought someone would know how to power it up without tearing apart another car just to test it. Thought another thread would be useful for someone trying to bench test their DIC.
  4. #4 Re: Bench Test Driver Information Center (DIC)
    That Loud Guy 1LoudGrandPrix's Avatar
    Cedar Rapids, IA
    Quote Originally Posted by jejensen View Post
    i bet i can get that "hard to remove" panel out in 5min tops
    98 Camaro SS 46k LS1, T56, All Stock. 00 GMC Sierra 2wd ECSB 106k Lm7, 3.73s tow needs lowered..
    01 Grand Prix GTP "201k" ~111k on motor, ~46k on trans, headers, 3.4 and a tune to come.
    01 Grand Prix GT 168k: Mods: Tune by TheOtherNick. Stereo: 320A alt,4 runs 0/1, XS D3400 front, 1 JYP 80ah Lithium rear, 2 Twisted Sounds 3500s, 2 Sundown Audio NightShade v.3 7 National Records..
  5. #5 Re: Bench Test Driver Information Center (DIC)
    Quote Originally Posted by TurboTrav View Post
    less than that... are you kidding?
    I dont think it'd work unless you had it hooked up to a PCM so it seems like a waste of time.
  6. #6 Re: Bench Test Driver Information Center (DIC)
    Iowa
    Yeah, I can remove it pretty quickly too but didn't really want to tear into my buddy's GP to test the DIC if I didn't have to.
  7. #7 Re: Bench Test Driver Information Center (DIC)
    GTX Level Member kjohnson's Avatar
    Nov 2008
    Harlan, IA and University of Northern Iowa
    just go diggen so you know the answer. make sure that all of the wires are firm in the plug for the dic. i know its a stupid thing to look at but if you have it apart it takes like 4 sec.
    silver 2003 Grand Prix GT List is on it's way to be updated
  8. #8 Re: Bench Test Driver Information Center (DIC)
    Iowa
    Can the DIC be bench tested with just a 12VDC power supply or do I need the Body Control Module (BCM) and/or Powertrain Control Module (PCM) to light up the LCD display?
  9. #9 Re: Bench Test Driver Information Center (DIC)
    Iowa
    I have seen eBay sellers show these DIC modules lit up on a bench (including LCD) so it must be possible. Does anyone know how to do this?
  10. #10 Re: Bench Test Driver Information Center (DIC)
    Donating Users Mikey's Avatar
    Apr 2009
    Virginia Beach
    Yes, Connect the grey - pink - orange together on a 12+ volt dc supply or car battery. The two blacks are obviously ground, to the negative. I just did this and installed my DIC this past weekend!
  11. #11 Re: Bench Test Driver Information Center (DIC)
    Apr 2009
    Virginia Beach
    Her is the plug view.
  12. #12 Re: Bench Test Driver Information Center (DIC)
    Iowa
    Thanks Mikey for the schematics and letting me know which wires to connect for bench testing!
  13. #13 Re: Bench Test Driver Information Center (DIC)
    Apr 2009
    Virginia Beach
    Here's my old one on the bench so it can be done.
  14. #14 Re: Bench Test Driver Information Center (DIC)
    Iowa
    Is that an LCD panel showing the outline of the car or is it similar to the other warning indicators on the right side?
  15. #15 Re: Bench Test Driver Information Center (DIC)
    Apr 2009
    Virginia Beach
    Yes it is the cars outline. The other are signal driven from the pcm & bcm. This is my old one. The other has a digital display. This one just has light bulbs in the back.
  16. #16 Re: Bench Test Driver Information Center (DIC)
    Iowa
    Did you test your digital display before installing it using the wiring connections you mentioned earlier?
  17. #17 Re: Bench Test Driver Information Center (DIC)
    Apr 2009
    Virginia Beach
    Yes and the whole display lit up just like the pic you show earlier. That way I would know not to waste my time installing it if it was dead.
  18. #18 Re: Bench Test Driver Information Center (DIC)
    Iowa
    That's exactly what I needed. Many THANKS!!
  19. #19 Re: Bench Test Driver Information Center (DIC)
    Apr 2009
    Virginia Beach
    No Prob Bro!
  20. #20 Re: Bench Test Driver Information Center (DIC)
    Jul 2010
    Coquitlam,BC,Canada
    Thread resurection time.
    I have two digital GTP DIC's here, and when I bench test them per Mikey's instructions, the only thing that lights up is the TCS light. I'm no slouch with wiring, but I'm sure I am doing something wrong.
    Mikey, do you have your pictures hosted anywhere? Can you post a link to them?
    Also, is the plug/harness from a regular GT DIC different from the digital GT or GTP harness? All that I can find mentioned is the number of wires (18 vs 24), and in this write-up ( 97-03 GP Digital Drivers Information Console Install ) buddy says, "I went ahead and just cut the old connector off and stripped the wires on both the body harness as well as the digital DIC pigtail", so I'm guessing that they are different?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  2. Driver Information Center
    By techn9cian99GTP in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 10:02 AM
  3. Driver Information Center (DIC) Blank
    By jejensen in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2010, 02:25 PM
  4. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
  5. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
