Thread: Bench Test Driver Information Center (DIC)
Results 1 to 20 of 25
  1. #1 Re: Bench Test Driver Information Center (DIC)
    Jul 2010
    Coquitlam,BC,Canada
    Thread resurection time.
    I have two digital GTP DIC's here, and when I bench test them per Mikey's instructions, the only thing that lights up is the TCS light. I'm no slouch with wiring, but I'm sure I am doing something wrong.
    Mikey, do you have your pictures hosted anywhere? Can you post a link to them?
    Also, is the plug/harness from a regular GT DIC different from the digital GT or GTP harness? All that I can find mentioned is the number of wires (18 vs 24), and in this write-up ( 97-03 GP Digital Drivers Information Console Install ) buddy says, "I went ahead and just cut the old connector off and stripped the wires on both the body harness as well as the digital DIC pigtail", so I'm guessing that they are different?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #2 Re: Bench Test Driver Information Center (DIC)
    GT Level Member Tea Time's Avatar
    New Brunswick
    Quote Originally Posted by Bronco Boy View Post
    Here you go kid...HOW - TO
    http://www.grandprixforums.net/addin...3-gp-8171.html
    '00 GTP - Summer Toy
    '97 GTP - Project
    '99 GT - Gone (Frame Rotted)
    '98 SE - Gone (Parts Car)
  3. #3 Re: Bench Test Driver Information Center (DIC)
    Apr 2011
    Elk Rapids, Michigan
    The analog DIC has an 18 pin connector. The digital DIC has a 24 pin connector. You don't mention what year GP you have. My 2000 GT did not have both 18 and 24 pin connectors so I had to splice the 24 pin per the table in the post in the previous post There's also a write up in the "how to" section. If you have a 97 to 99 GP you should have both connectors already in the body harness, you'll just have to dig behind the dash to find it. If you have that then you should also have the connector should you decide to add the HUD.
  4. #4 Re: Bench Test Driver Information Center (DIC)
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by Tea Time View Post
    Kid? Wow! Haven't been called that in over 30 years.
    I've already read that thread a few times and it doesn't have the answers to my questions.
    Quote Originally Posted by ExLimey View Post
    The analog DIC has an 18 pin connector. The digital DIC has a 24 pin connector. You don't mention what year GP you have. My 2000 GT did not have both 18 and 24 pin connectors so I had to slice the 24 pin per the table in the post in the previous post There's also a write up in the "how to" section. If you have a 97 to 99 GP you should have both connectors already in the body harness, you'll just have to dig behind the dash to find it. If you have that then you should also have the connector should you decide to add the HUD.
    I have a 2002 GT. I don't plan on ever adding the HUD (they look butt-ugly IMO). So '00+ possibly don't have both connectors then. Thanks for the info.
    Now to figure out the bench testing.....
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. driver information center
    By bc1 in forum General Tech Discussion
    Last Post: 12-12-2010, 10:21 AM
  2. Driver Information Center
    By techn9cian99GTP in forum Audio, Security & Visual Electronics
    Last Post: 12-12-2010, 10:02 AM
  3. Driver Information Center (DIC) Blank
    By jejensen in forum Audio, Security & Visual Electronics
    Last Post: 05-13-2010, 02:25 PM
  4. Driver information center
    By sbrutcher in forum Introductions/Noob Questions
    Last Post: 02-13-2010, 03:20 PM
  5. driver information center
    By Green Machine in forum General Tech Discussion
    Last Post: 08-05-2008, 12:14 AM
