Thread: Sudden issue under boost
Page 3 of 3 FirstFirst 123
Results 41 to 60 of 60
  1. #41 Re: Sudden issue under boost
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    so bill, can you source audi parts at a bone yard , or are they impossible to find at one ? i had a 93 Z24 and could never find parts at the junkyard.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  2. #42 Re: Sudden issue under boost
    Adam.. there's a how to swap it out on here...just search on my name and "ea sy" without the space. then hit car-part.com and get one for $100-300 and do the swap yourself. Quick eas y and done.
  3. #43 Re: Sudden issue under boost
    Feb 2015
    Swapping is no problem, im a heavy equipment mechanic but figured hell I love this car might as well stick some coin into it......I wasn't expecting sink more than what I paid for the whole damn car!
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  4. #44 Re: Sudden issue under boost
    don't drive like me and you won't. lol
  5. #45 Re: Sudden issue under boost
    Feb 2015
    It's hard not to see that boost climb!
  6. #46 Re: Sudden issue under boost
    On your lego block gauge? LOL don't get me started on GTp's.. they are Giant Trash Piles.
  7. #47 Re: Sudden issue under boost
    Feb 2015
    Hahahahaha yeah I can't understand why the sweet hud and a god awful boost guage
  8. #48 Re: Sudden issue under boost
    Bonnie has good gauge and hud
  9. #49 Re: Sudden issue under boost
    Feb 2015
    I haven't seen the bonnie guage
  10. #50 Re: Sudden issue under boost
    It's next to the oil pressure gauge. no lego blocks. real numbers. -10 psi to +10 psi. so the second you add a pulley, it's worthless
  11. #51 Re: Sudden issue under boost
    i know a regal boost gauge will read up to 12 psi im sure it will read higher too.
    and then theres the part where i never give a crap to look at it too lol
  12. #52 Re: Sudden issue under boost
    Feb 2015
    Well I went and picked my new plugs and wires up this morning. If not for #6 it would have been a 30 minute job. Anyway I pulled the 3 out of the front bank and inspected them. Number 5 had a hairline crack in the insulator. Other than that nothing was out of the ordinary. Test drove it and everything is back to normal! Thank you guys for all your input!!
  13. #53 Re: Sudden issue under boost
    that crack will cause a major misfire for sure.
    if you have a real spark plug socket its got a bolt head on the socket, you can use a wrench to break it free and clear the o2 sensor.
  14. #54 Re: Sudden issue under boost
    Feb 2015
    Damn i never thought to do that, it's kind of odd a 3 inch extension is to short and a 6 inch damn near hits the firewall.
  15. #55 Re: Sudden issue under boost
    i used to use a 3 inch, put the socket on the plug, then you can only get the very tip of the extension in the socket, like to the check ball on the side, then crack it free.
    once you do headers a plug change is so easy your head will spin, the back is as easy as the front then. oh, and taking off all the pull brackets also free's up room. i dont even need to rock the engine forward since i got headers.
  16. #56 Re: Sudden issue under boost
    agreed..that #5 was your issue. Glad it's all fixed.
  17. #57 Re: Sudden issue under boost
    Feb 2015
    I've heard that iridium plugs will crack but I've never actually seen it first hand
  18. #58 Re: Sudden issue under boost
    any plug can crack. most of the time it can happen on install if not using a real plug socket, they have a foam insert that keep it from cracking.
  19. #59 Re: Sudden issue under boost
  20. #60 Re: Sudden issue under boost
    Feb 2015
    That would have made things a lot easier
  1. BBV/ boost issue
    By scottgs03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2013, 07:59 AM
  2. Boost issue..
    By Trista Jeanne Lemer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-29-2012, 08:10 PM
  3. BOOST issue
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 02:24 PM
  4. Another Boost Issue Thread
    By Biohazed in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-28-2011, 03:21 PM
  5. Boost issue
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 02:13 AM
