Thread: Cylinder 3-4-5 misfire
Results 1 to 6 of 6
  1. #1 Cylinder 3-4-5 misfire
    Jun 2015
    Decatur, MI
    My 99 GTP is having misfires on cylinders 3, 4, and 5. Cylinder 4 is having about twice as many misfires as cylinder 3 and 5. The only thrown code is for random misfire, it never specifies cylinders. It only causes problems when I am hard on the gas, gentle acceleration works without issue.
    This problem has persisted for around two years now and hasn't gotten any worse. I've tried attacking the problem a few times and can confirm with near 100% certainty it is not a plug/wire/coil pack problem nor is it a vacuum leak. I took it to a GM certified mechanic and he didn't find the problem but suggested I change the injectors, is this likely the problem? How can three injectors go bad at the same time (I think it works this way?) ?
    The best advice is to take it to a junkyard but any other advice would be appreciated, thanks!
  2. #2 Re: Cylinder 3-4-5 misfire
    Possible ICM issue could be present.
    If you can swap an ICM from another car just to try it, it would be worth it.
  3. #3 Re: Cylinder 3-4-5 misfire
    Jun 2015
    Decatur, MI
    Thanks, I've never heard that suggestion. I'll have to make a junkyard visit in the near future.
  4. #4 Re: Cylinder 3-4-5 misfire
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    Ive got a couple sitting around if you'd want one. Just PM me.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  5. #5 Re: Cylinder 3-4-5 misfire
    Jun 2015
    Decatur, MI
    I put a different ICM in today, no improvement. Further testing shows cylinder 4 misfiring at idle but under a load it either isn't or isn't severe. Cylinder 3 is a bit, but cylinder 5 goes haywire.
  6. #6 Re: Cylinder 3-4-5 misfire
    Apr 2014
    South Haven, MI
    How do the plugs on those cylinders look vs the non misfiring ones? You could also try switching the injectors around and seeing if the misfire follows.
  1. Cylinder 1 Misfire PLEASE HELP
    By viking55976 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-10-2013, 09:09 PM
  2. Cylinder #2 misfire
    By EJOUIE in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-22-2011, 07:38 PM
  3. Misfire in Cylinder 5
    By 06gtSC in forum General Tech Discussion
    Last Post: 04-19-2011, 03:50 PM
  4. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  5. Cylinder #1 misfire and random cylinder misfire
    By whodat79 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-21-2010, 07:16 AM
