Thread: Another Boost Issue Thread
Results 1 to 10 of 10
  1. #1 Another Boost Issue Thread
    GTX Level Member Biohazed's Avatar
    Philadelphia, Pennsylvania, United States
    OK as the title states I am having boost issues with the GTP. Been battling this since I got it .. Changed the BBV, all new Vac Lines, and Last week changed out the Fuel Pressure Regulator ... after that I had 8PSI constant ... that lasted for 2 days ... now sometimes I can get full boost but only very occasionally... Usually is putting out about 3 psi ... On my Mechanical Boost gauge, at idle I'm reading 20 inHG steady so It definatly does not seem like a Vac leak. so I'm really at a loss at this point. any help would be very appreciated.
    *image too tall*
    BMR F + R Strut Bars - Falken Torque V 18's - JVC S900 - Kicker C10's - Spyder Projectors, Wizaird,
  2. #2 Re: Another Boost Issue Thread
    Akron Ohio
    Belt slip?
  3. #3 Re: Another Boost Issue Thread
    Tensioner seems fine, no glazing, noise or any other signs of belt slippage, oh and if it helps it has a Stock pulley still, I havea 3.4 MPS but it hasn't made its way onto it yet, lol
    *image too tall*
  4. #4 Re: Another Boost Issue Thread
    Akron Ohio
    Have you tried a new belt?
  5. #5 Re: Another Boost Issue Thread
    Akron Ohio
    I about **** my pants trying to get a new belt on so they do fit tight.
  6. #6 Re: Another Boost Issue Thread
    belt on it only has maybe 2000 miles on it and is in great shape still.
    *image too tall*
  7. #7 Re: Another Boost Issue Thread
    Feb 2008
    Did you tighten the adjustment nuts on the BBV all the way? May have slipped and not closing the butterfly all the way.
  8. #8 Re: Another Boost Issue Thread
    I'll check that tonight, pretty sure I had it tightened tho. whats the possibility its the Boost Solenoid?
    *image too tall*
  9. #9 Re: Another Boost Issue Thread
    You say you replaced the BBV.. which is a part we don't have, so I'm not 100% sure if you replaced the black can looking item the Actuator or the little electrical Soleniod.
    Typically I've noted the soleniod being bad and causing this kind of issue
  10. #10 Re: Another Boost Issue Thread
    i replaced the Black can looking thing :P ordered a Solenoid today will have it tomorrow hope this fixes it ./... tired of this thing not boosting right .. lol
    *image too tall*
  1. BOOST issue
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-27-2011, 02:24 PM
  2. Boost issue
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 02:13 AM
  3. boost gauge issue vid
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2009, 09:44 PM
  4. Possible Final Thread, Trans Issue
    By GPSims39 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-09-2009, 09:52 PM
