Thread: Boost problems
Results 21 to 40 of 58
  1. #21 Re: Boost problems
    He never called that the evap, he said he deleted his evap.
  2. #22 Re: Boost problems
    he said those two ports are sealed off as i deleted my evap. iirc. ether way its wrong.
  3. #23 Re: Boost problems
    Well yeah.
  4. #24 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    And there you go.
    Jeff
  5. #25 Re: Boost problems
    Jeff...are you seeing something there?
    No worries guy.. Jeff used Ford check valves on his!
  6. #26 Re: Boost problems
    Mar 2015
    Western North Carolina
    Then wat are the other 2 lines off the t on top of the supercharger for u guys dnt have to b a dick about it god so I thought they where to sumthing else everyone makes mistakes ya kno
  7. #27 Re: Boost problems
    i posted a diagram, read it please.
  8. #28 Re: Boost problems
    Mar 2015
    I did man I fixed them the way the diagram shows but I still have one that nothings hooked to its the one closes to the break booster hose do I just need to block it off?
  9. #29 Re: Boost problems
    that one goes to the vac line thats clipped to the fire wall, then runs down the pass side fender, its what controls your hvac air flow.
    see the line in the pic to the fire wall?
    one more pic whore of the bee lol
  10. #30 Re: Boost problems
    You have to kinda wish Scotty warned you that sunglasses would be needed before looking at his picture I bet.
  11. #31 Re: Boost problems
    you love that color, stop it lol
  12. #32 Re: Boost problems
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    the braces and dog bones need painted too.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  13. #33 Re: Boost problems
    the whole bay needs to be painted up. it looks like crap. all i see is clean shinny engine in a dirt filled hole lol
  14. #34 Re: Boost problems
    Dec 2014
    Maryland
    it's 10x better than my dirty oily engine in a dirt filled hole...lol ...i got so much crud and oil built up i can't tell where the leaks are. got 2 cans of oven cleaner i need to cut loose in there.
  15. #35 Re: Boost problems
    Mar 2015
    ok I got it all fixed the way your pic looks an the diagram I ran it an it was worse now its only showing like 1.2psi at wot heres a link to the pic let me kno if I did sumthing wrong again http://s292.photobucket.com/user/BLA...tml?sort=3&o=1
  16. #36 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    it came like that! Lol. I've only had the car since late April.
    Guys I'm not very familiar with the pre 04' models and I have only worked on NA versions of the 3.8 Buick engine. The thing that's throwing me is I have several different Gen 3 blowers and some have the little vacuum tree that is held down by 1 bolt and another that the area is not used. So I'm at a little bit of a disadvantage on this system. I did notice the vacuum in the previous pic had one tube piped back to the same place.
    ill have to look at it some more.
  17. #37 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    Hold on wait a second... The pic on photobucket looks like you have a vacuum line going to the bypass solenoid, that should be coming from the manifold pressure side. Looks to me as though you have the bypass actuator fighting itself.
    Jeff
  18. #38 Re: Boost problems
    Mar 2015
    yea I seen that I unhooked it now its running back to around 5.5 6 psi but the belts slipping bad u can hear it squeal at wot so pretty sure the belts slipping but I got it all back the way the diagram an the yellow motor looks I really appreciate it guys
  19. #39 Re: Boost problems
    on the lower vac tree, you got two lines there, wheres the lower one going to? im thinking somethings not right bbv to actuator tot he tree.
    the pfr vac lines goes to the vac tree. ( it will work hooked up to the nipple under the snout tho, (if thats how its ran) under the snout goes to the map only, and your boost gauge.
    theres two ports on the bbv, one goes to the actuator
  20. #40 Re: Boost problems
    the side view of the bbv and its actuator and that line. theres two ports there, one stays open its got a funny looking clip there, it used to hold that foam you see in this pic, yours is likely long gone. if its gone, its fine. most of use dont have it any more.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost gauge problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 12:21 AM
  3. 99 Gtp boost problems
    By justrunningagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 05:40 PM
  4. Autometer boost gauge problems
    By Kairocross in forum General Tech Discussion
    Last Post: 06-13-2011, 09:24 PM
  5. 2005 GTP Comp G Boost problems!
    By 05GTPcmpg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 11:00 PM
