Thread: boost gauge problems
Results 1 to 20 of 35
  1. #1 boost gauge problems
    GTP = BEAST 04PrixGTP's Avatar
    Houston
    so i installed the boost gauge on my 04 grind prix gtp and im gettin vaccume but when i floor it i hear my supercharger winnin but my boost gauge aint showin no boost i think i hooked it to the wrong place i hooked it up to what looks lk a vac source or something its on top the s/c
    My 04 Grand Prix GTP is a BEAST
  2. #2 Re: boost gauge problems
    yea, you connected it to the wrong line.
    Connect it to the line going around the LIM and supercharger. that line will show boost
  3. #3 Re: boost gauge problems
    Houston
    Whats a LIM
  4. #4 Re: boost gauge problems
    lower intake manifold.
    look under the snout of the supercharger, there will be a vacuum T there, follow it and find a spot where you can T into that line.
  5. #5 Re: boost gauge problems
    Houston
    yep..pretty much T into the line right behind your alternator.
  6. #6 Re: boost gauge problems
    Houston
    ok ill go take a look right now brb
  7. #7 Re: boost gauge problems
    Houston
    Right around here......
  8. #8 Re: boost gauge problems
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    do you pull the vacumn line out of the MAP sensor or do you pull one of the lines off the T thats under the s/c snout
    SOLD. 99 GTP - Open Cone, ZZP STB ,GMPP Front & Rear Sway Bar, 3" DP & Cat-Back, Built Trans, 12'' Brakes, Tune
    http://www.grandprixforums.net/gtp-t...ack-67489.html
    04 SRT4 - Bone Stock....For Now
  9. #9 Re: boost gauge problems
    Houston
    i went to look its like a hard plastic line right ?
  10. #10 Re: boost gauge problems
    correct.
  11. #11 Re: boost gauge problems
    Houston
    ok so how to i T into that little ass line ?
  12. #12 Re: boost gauge problems
    Quote Originally Posted by 04PrixGTP View Post
    take the L nipple off your MAP sensor (it will be the final place the vacuum line goes at the rear of the supercharger), replace it with a T, and continue the line to the cabin of the car.
  13. #13 Re: boost gauge problems
    Houston
    yea i just hooked it up im runnin 6 psi is that normal for stock ?
  14. #14 Re: boost gauge problems
    Feb 2008
    Sounds about right for stock.
  15. #15 Re: boost gauge problems
    Houston
    if i get a 3.2in pully how much boost would i get then or is there something esle i can do to get more boost
  16. #16 Re: boost gauge problems
    GTX Level Member tayl5645's Avatar
    Jul 2010
    Michigan
    Do you have other mods done before you just slap on a pully??? better have a good amount for that size.
    EDIT!!! On a 04!!! thats like dropping to a 3.0 on the 97-03 that would be insane without a ton of mods!!! plus a way to scan for that knock
    2005 GTP Grey
    Custom built Open cone intake, 15% tints all the way around, 7" touchscreen DVD player
  17. #17 Re: boost gauge problems
    Houston
    yea i got wires intake and exhaust system
  18. #18 Re: boost gauge problems
    Jul 2010
    Michigan
    your going to need a tune for sure
    2005 GTP Grey
  19. #19 Re: boost gauge problems
    Houston
    yea im tryin to find a good tunning place around here no luck so far
  20. #20 Re: boost gauge problems
    swift current,sask.
    You are going to need more like headers, intercooler/ cam, and a really good tune for that pulley
  1. Why is my boost gauge only reading vacuum and no boost?
    By gtp02 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-21-2010, 02:26 PM
  2. dic boost gauge only shows half boost
    By SilvaMan61 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-10-2010, 07:40 PM
