Thread: Too much crank case pressure
Results 1 to 12 of 12
  1. #1 Too much crank case pressure
    Jul 2015
    cook mn
    Hey guys having a big problem with my car, one day it started real ruff and I looked under the hood and the manifold was glowing orange. Gauges said it wasn't overheating. Well from this it burnt up the front three plugs. Changed those and put a new catalytic converter as well. Now it runs ruff and when giving it some throttle it shoots the dipstick out and sprays oil everywhere. I checked the pcv valve and that is still good. It also doesn't throw any codes so I'm stuck between a rock and a hardplace!
  2. #2 Re: Too much crank case pressure
    Apr 2015
    Columbus, OH
    Can you get a video of this dipstick shooting monster in action? Not so much because I think it will help...I'd just like to see it.
    But you either have a pcv issue or no compression rings on your pistons.
    Edit: what kinda car?
    Top Swapped 01 Imp
  3. #3 Re: Too much crank case pressure
    your not gonna like this, but thats caused by whats known as blow by. it means your rings are shot to hell. aka find a new used engine.
  4. #4 Re: Too much crank case pressure
    Apr 2015
    Columbus, OH
    Yup. But I'd still like a video
    Top Swapped 01 Imp
  5. #5 Re: Too much crank case pressure
    Kemmerer, Wyoming
    it doesn't necessarily have to be blowby, it could be too much crankcase pressure. in my case it was because the intercooler pcv line had rtv in it so the pcv was plugged. you could try putting a breather on the front valve cover to relieve some of the pressure, but that isn't a good permanent fix.
  6. #6 Re: Too much crank case pressure
    its dead. he checked his pcv.
    glowing manifolds killed it. its over heated and baked the rings i bet.
    do a compression test.
  7. #7 Re: Too much crank case pressure
    Kemmerer, Wyoming
    isn't there another place the pcv could get plugged?
  8. #8 Re: Too much crank case pressure
    GXP Level Member
    Mar 2015
    Tomball
    I'd have to agree with Scotty on this I have had this happen on a friends S-10 he had about 80 psi on the right bank and a clogged cat. Compression test is easy on the front 3 cylinders anyway easy check.
    Jeff
  9. #9 Re: Too much crank case pressure
    But no one ever wants to do a comp. test.
    We had this happen on a clogged coverter/PCV issue.
    Good thing we caught it in time, but man...it got toasty.
  10. #10 Re: Too much crank case pressure
    GXP Level Member
    Mar 2015
    Tomball
    Hell I did it twice.
  11. #11 Re: Too much crank case pressure
    Quote Originally Posted by J57ltr View Post
    lies, all lies lol what a call back to a another thread...............
  12. #12 Re: Too much crank case pressure
    GXP Level Member
    Mar 2015
    Tomball
    Lol
  1. Crank case pressure
    By gtpsleeper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2013, 01:03 AM
  2. No crank, just click. Replaced starter, still no crank.. help!!
    By Steve98GTP in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-17-2013, 08:48 PM
  3. Question about L32 crank case pressure
    By RamairGTP2 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-16-2012, 02:29 PM
  4. How do you perform a crank case relearn?
    By GOTIT4CHEAP16 in forum PCM Tuning
    Last Post: 08-16-2010, 06:28 AM
