Thread: Is the 97 Grand Prix GT 3.8L the same block as the 97 Grand Prix GTP 3.8L SC
Results 1 to 2 of 2
  1. #1 Is the 97 Grand Prix GT 3.8L the same block as the 97 Grand Prix GTP 3.8L SC
    Jul 2015
    Avery Co NC
    My 97 Grand Prix GTP 3.8L turned a rod bearing and i need to know if i can buy a GT 3.8L and just put my Supercharger on it and it be the same? if the heads and cam are diff then i can use my heads cam timing all that stuff.
  2. #2 Re: Is the 97 Grand Prix GT 3.8L the same block as the 97 Grand Prix GTP 3.8L SC
    St. Louis
    Doing that is what will result in what we call a "top swap", as the pistons are different in the N/A blocks which results in a higher compression ratio. I'd stick to finding another supercharged motor and leave it be. GP's, Regals, Bonnevilles are some other 3.8L cars that came supercharged factory so don't limit your search to just the GP's.
  1. 2004 Grand Prix Comp GTP Rear Fenders/Quarters and Grand Prix Parts***
    By luckydogaroo in forum General Grand Prix Discussion
    Last Post: 01-30-2015, 04:00 PM
  2. Replies: 8
    Last Post: 10-28-2012, 03:58 AM
  3. 04 Grand Prix Fuse Block map
    By btempelman in forum General Tech Discussion
    Last Post: 03-15-2009, 03:38 PM
