Thread: Boost problems
Page 1 of 3 123 LastLast
Results 1 to 20 of 58
  1. #1 Boost problems
    Mar 2015
    Western North Carolina
    het guys I have a 97 gtp im have boost problems I was showing about 8 psi then I done some more mods an now its only showing 2.5 psi its showing it around 3500 to 5000 rpm after that it drops even more to around 1.8 an I cant figure out what is going on any help you guys could give I would really appreciate ill give u a list of my mods at the bottom
    p&p s/c
    p&p lim
    3.3 s/c pulley
    cai
    high flow fuel filter
    3" catless down pipe
    new crankshaft .010
    new 3800 Powdered Metal Connecting Rods
    new crank an rod Bearings .010 under
    new cam Bearings
    new piston rings
    140# valve springs
    xp hot cam
    double roller timing chain
    new oil pump
    resurfaced heads an block
    zzp 1.0 PCM
    new tranny
    new Tensioner
    ac delete
    o2 sim
    alt booster
    front power log
    egr delete
    autolite 103s gapped at .50
    new maf,iac,tps
    got a new sc belt on the way
    new plug wires
    I believe that's everything once again thank you guys for your help
  2. #2 Re: Boost problems
    Disconnect the vacuum line between the boost soleniod and actuator. Go for a drive..if boost is back, it's a bad soleniod.
  3. #3 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    What Bill said, then Who ported and polished your SC and LIM? Do you have any pics of them? I guess the car runs fine other than the boost?
    Jeff
  4. #4 Re: Boost problems
    Awesome Level Member chrsmi1's Avatar
    Jan 2013
    Raleigh, NC
    Where in western NC you at? I live in Raleigh and have family in Statesville i'll be visiting week after next (going on a cruise monday, stopping by on the way back for a few days). If you haven't got it by then we could get together and i could give you a hand. I love working on GP's.
    Like Bill said though, check your vacuum lines and actuator. Don't just assume they're right or anything like that, go through the lines systematically.
    Comp G. E85, 2.8, Headers, Tune, Intake, S1X, 105# springs, 60 # injectors, 255 walbro,etc.
    *NEW* 2002 Camaro Z28- Lid, Headers, Catback
  5. #5 Re: Boost problems
    Mar 2015
    I already bypassed the boost solenoid first thing I tried after reading sum other forums an checked the bypass valve zzp did the p&p sc an lim I'm just really puzzled I looked at the vaccum diagram an traced it back to see if everything was rite an it seemed like it was the way the pic showed idk tho ive tried everything I can think of I ordered a new sc belt just incase it was slipping I hadn't got it yet I'm really hoping its that chrsmi1 I leave up around boone nc
  6. #6 Re: Boost problems
    Jeff..you know what to do. Walk him through step by step, and make sure you get the pictures of the ford check valve. lol
  7. #7 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    Well let's see some pictures of the nipple under the snout of the supercharger. A picture of the line to the bypass solenoid and bypass valve. Then a picture of the tubing to the MAP sensor. There is another vacuum like on the pre 04' cars so one of that as well. How does the power feel? Does it feel like you have 2.5# of boost?
    Jeff
  8. #8 Re: Boost problems
    Mar 2015
    Uh it feels a bit sluggish it's not as potent as it was with the boost but it's not dead in the water feeling ya kno but ill Def get you sum pics of the vaccum lines an the t under the supercharger an to the bbv I really do appreciate you guys help on this
  9. #9 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    Man I just got through a situation with NO boost so we should be able to solve this pretty easy.
    Jeff
  10. #10 Re: Boost problems
    Quote Originally Posted by J57ltr View Post
    Jeff
    Especially since you tested/checked everything twice. I'm also watching, just busy. Figured you had this one.
  11. #11 Re: Boost problems
    GXP Level Member
    Mar 2015
    Tomball
    At least twice. Let us know even if you find the problem without having to post pics. That way others can benefit from your solved issue.
    Jeff
  12. #12 Re: Boost problems
    Mar 2015
    It won't let me post any pics for some reason but I'm gonna make a video of the lines an everything an give you a link to it I just noticed when I was messing with it when the cars running if u hit the throttle the supercharger belt has alot of movement in it so I'm starting to wonder if the belts just shot on the supercharger cause when I rebuilt everything I put a new supercharged tensioner on her an idk if the belts ever been changed I kno I hadn't changed it since I've owned it I did order a new one just waitn for it to come in but I'll have a link up to the video asap thanks guys
  13. #13 Re: Boost problems
    Send a picture of the SC belt tensioner and where the two nubs on the back are sitting on the coil bracket to my user name at gmail.com
    To post pics etc.. use a hosting site like photobucket and link the img here.
  14. #14 Re: Boost problems
    Blackandredgtp upload pics to photobucket or something similar then link them here.
  15. #15 Re: Boost problems
    Yawn.. ^^^ sounds familiar lol
  16. #16 Re: Boost problems
    You ninjad me bill
  17. #17 Re: Boost problems
    Mar 2015
    heres a link to youtube where the video is I gotta get to work but ill check back with u guys when I take a break https://youtu.be/nyMDcuEtuWo
  18. #18 Re: Boost problems
    you did your lines all wrong. your evap is on the TB, the fat port, not the two lines on the tree atop the sc. one of those lines goes to your hvac to power where the vents blow to, the other goes to the bbv.
    do over time. no wonder you got no boost........
  19. #19 Re: Boost problems
    DAmmmmit, I couldn't see it at .. er work so I was gonna review on the way to the car.
    Scotty for the ...whine!
  20. #20 Re: Boost problems
    bill dont be drinking anything when you watch the vid lol the loop between the two sc tree ports is priceless even more so when he calls it the evap. lol
    but it runs so theres hope. some quick re doing of them lines will make the car feel right again.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost gauge problems
    By 04PrixGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-27-2012, 12:21 AM
  3. 99 Gtp boost problems
    By justrunningagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2012, 05:40 PM
  4. Autometer boost gauge problems
    By Kairocross in forum General Tech Discussion
    Last Post: 06-13-2011, 09:24 PM
  5. 2005 GTP Comp G Boost problems!
    By 05GTPcmpg in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2011, 11:00 PM
