Thread: Issue after intercooler install, car revs high then drops way low
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 21 to 40 of 98
  1. #21 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Where winter never ends
    Intercoolorer core isn't sealed together. Zzp has issues with this
    2000 Regal - Winter Beater
  2. #22 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    I resealed the IC myself with rtv.
    02 Grand Prix GT Mods' Top Swapped Gen 3, Stage 2 IC, 3.0" MPS, 42# injectors, 1.8 Yella Terra roller rockers, Speed Daddy Headers, CAI, Self Tuned, 180 tstat, ram air hood, front/rear sway bars/and STB's AL 104's, 12' Dual Piston Break kit
  3. #23 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Well then can tell at all where something is leaking? Any codes?
  4. #24 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    P0107 manifold absolute pressure sensor low,
    P0102 nice or volume air flow a circuit low,
    P 1107 manifold absolute pressure sensor circuit intermittent low voltage.
    The car will start up then die right after so I do not really have time to check for leaks.
  5. #25 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    What year?
  6. #26 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    2002, my Sig has all my mods as well.
  7. #27 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    I'm on Tapatalk can't see your SIG, is your map sensor plugged in/hooked up?
  8. #28 Re: Issue after intercooler install, car revs high then drops way low
    Tapatalk is a joke I wish people would just use regular mobil web viewer.
  9. #29 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    If you think Tapatalk is a joke you have a broken head
  10. #30 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    Yeah it's hooked up, I'm getting readings from it in hp tuners. It's around 40 KPA with the engine on.
  11. #31 Re: Issue after intercooler install, car revs high then drops way low
    Quote Originally Posted by ADecker View Post
    no when on my phone I view the forum as fullsite screw that tapatalk nonsense.
  12. #32 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Something is up with your map... Check it again. Cord, vac line
  13. #33 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Meh Tapatalk makes it easy
  14. #34 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    My vac line is routed from the lim to fpr where it has a T, then from there to my map sensor. Yes my fpr is on the other side of the fuel rail. Any problems there? I have checked the line a few times and see no cracks.
  15. #35 Re: Issue after intercooler install, car revs high then drops way low
    Nov 2013
    United States
    You might have to do a smoke test to find the leak, or just spray around with starter fluid. When the engine revs up you know you found the leak.
  16. #36 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Yep do that
  17. #37 Re: Issue after intercooler install, car revs high then drops way low
    Kemmerer, Wyoming
    instead of spraying around with starter fluid I use a propane blow torch and am just careful not to ignite the flame.
  18. #38 Re: Issue after intercooler install, car revs high then drops way low
    May 2012
    Wut?! That's insane.
  19. #39 Re: Issue after intercooler install, car revs high then drops way low
    Kemmerer, Wyoming
    does the same thing as starter fluid but is probably safer because it wont puddle anywhere
  20. #40 Re: Issue after intercooler install, car revs high then drops way low
    Sep 2014
    United States
    We all agree it's a leak so I'm going to take the ic out of the equation, just want to make sure it's not a problem with the modified lim.
  1. How to install your WBS Intercooler
    By machinegunsquid in forum How To Write-Ups/Tech Tips
    Last Post: 07-11-2019, 08:02 PM
  2. 1999 Grand Prix GT Trans revs high
    By pilgrim in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-03-2012, 12:42 AM
  3. high revs as i start car
    By Jrs1987 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-05-2011, 06:28 PM
  4. High Revs, Late Shifting, and low HP
    By Wigsos in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-30-2010, 09:24 AM
  5. how do you install an intercooler??
    By blowfishRus6 in forum General Tech Discussion
    Last Post: 05-25-2008, 12:15 AM
